| | | Forums66 Topics128,078 Posts1,055,935 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Now that I have great working breaks. I’d like to switch out my gears to get a little more speed.
I have an original 1949 rear axle in a 3600 3/4 ton. I’m hoping to find a set of gears to swap out the original set if there is such a thing. Currently my top speed is 47 mph.
Can anyone point me in the right direction to purchase these gears?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | Those gears are sold by the same company that has powdered unicorn horn and bottled moonbeams. They just don't exist. A complete center section from a HO 72 axle from the late 1960's- - - -early 70's will bolt in, with a 4.10:1 ratio, but those things are also very scarce. That's probably because a lot of us dirt track racers scavenged them up and wore them out in the 1980's. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check. 4.10 is as good as you can hope for in the original axle housing. After that faster gears require an entire axle swap. Or an overdrive transmission. | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 |
| | | | | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | Probably 4.56:1 if it's a 3/4 ton. There's also a 5.14:1, but it was mostly in 3800 1-tons. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sorry, though I was replying to a post where you said you had 4.10 or 4.11.. either I was mistaken or the post vanished.
4.56 is most likely in a 3/4 ton | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We used to put 17" tires on our 3/4 tons with 4.56 rears and run them 65 to 70 all day long. If your engine is in good shape, running her at 3000 won't hurt it a bit. It will get noisy and don't expect very good fuel mileage because your vehicle isn't aerodynamic. If you gear the thing to turn 2000 at 65, you won't have enough power to run it there except down hill. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I’m running 4.10 gears and 32.5” or so tires for very comfortable 50-55 mph and can go 60-65 if needed. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Many times it isn't the truck that limits top speed, but rather it's the driver. High speed runs in an AD truck is LOUD. Cab noise, shakes, rattles, etc.
Just make sure all is in GREAT working order before the attempt. Good brakes, steering, tires, wheel bearings and all. Failure at high speed can have very bad results.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
