1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
46 1/2T, 235 engine, 4 speed. Originally sold as 3 speed but previous owner changed to 4 speed. Judging by the hole in the floor board, this did not change the location of the shift rod.
Today, satisfied engine was running well, made final adjustment to clutch linkage, fired her up and shifted into first gear - mashed (lightly) my knuckles into ash tray. Does anyone know why things aren't a little more friendly?
Bob
BobS46
Maybe the shifter is bent forward a bit. Wouldn't hurt to bend the lever a little toward the back, assuming that there's clearance to the seat (but that's softer than the dash).
Perhaps shifter from much later truck?
Just bend what you have to suit.
•1952 Chevrolet 3800 pickup
---All pictures---
One of the best (and cheapest) improvements I made to my '46 was to replace the worn shifter pin that goes in the ball of the shifter that moves the shift forks. Mine was super worn and I replaced it and that tightened up my shifting substantially. I used part of a drill bit (the smooth part) for a replacement pin. I might have seen the idea from an article on Jim Carter's web site where the sell the kit. I didn't need any of the kit parts but the pin which is not included was where my problem was.
Crusing in the Passing Lane
One could also use a roll pin.
Ed
Pull it out, heat & bend to the position you like. Clean up & paint it black.
BC
1960 C60 pasture art
Switched my '46 3 speed to a four speed. Required a different master brake cylinder mounting bracket and different floor pan. Shift lever position was/is fine. Does your shifter have a lockout on reverse? Straight cut gears with no synchros? Granny first gear? Is your master brake cylinder mounted on a bracket attached to the side of the trans? If so, these transmissions were available in these trucks from factory and your shifter is bent somehow - it'd take some doing, those shift levers are stout. If you've got a synchronized transmission, it's a retrofit of some sort and you're on your own.
