0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | After a long and painful search I finally found the front yoke and tranny plate I needed to make my 57 tranny work with my original 54 torque tube axle. The only remaining part I need to find is the rear yoke that fits the propeller shaft in the torque tube. I think and hope this yoke is more common than the last yoke which is made for the half ton 4 speed and also has the drive for the speedo drive gear. Can anyone tell me if any other year would this 54? Would a car yoke fit? Any differences in this yoke between the 3 and 4 speed? I know the 3/4 ton yoke wont work because its a 10 spline and I need a 17 spline.
Thanks for any comments | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What type of 1957 transmission?
The u-joint yoke that fits into the torque-tube does not have the speedometer gear on it.
The 3-speed and 4-speed yokes are different.
| | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | What type of 1957 transmission?
The 3-speed and 4-speed yokes are different. I should clarify things. Its an SM420. The yoke that bolts to the tranny shaft is what I have and it does have the speedo gear. The yoke I need is the slip yoke that slides on the propeller shaft inside the torque tube. I am thinking that yoke may be the same between the 3 and 4 speed and possibly similar year cars. As far as I know but could be wrong there is no difference in the axle in a 3 speed and 4 speed 3100. If the axles are the same that rear slip yoke should be the same as well. It might be a stretch to think a car yoke may fit but I think its possible. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1940-54 car and 1/2 ton do use the same rear yoke.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | 1940-54 car and 1/2 ton do use the same rear yoke. Sweet that's what I was hoping to hear. I'm tired of all these 54 truck specific parts that are impossible to find. I'm due for a commonly used part. | | |
