5 members (2-Ton, rfs56trk, J Lucas, Pete O, Barry Martak), 84 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
#1239518 10/16/2017 7:59 PM
Hello, I need a quick answer for some serious help. I am going to swap in a few weeks a 366 BBC into my 66 gmc 4000. IT has a 305v6 right now and a sm420. I need to know if I can swap the flywheel and the trans without issues onto my 366. If not what would I need to make this happen?
Crusing in the Passing Lane
The 305 flywheel might have a different bolt pattern. Which bellhousing are you going to use? The 305 might not bolt to the 366, also 420 retainer diameter might be too small for 366 bell housing. Many 366's have Clark 5 speeds, I have one.
Be best to determine all these issues first.
Ed
I know bell housing if diff now with research im buying a billet retainer ring soacer to use a sm465 bellhousing. Do you know about the flywheel thing? I can just buy a new flywheel thats no issue.
What happened to the 366 trans? It is often good to use the trans that goes with the new, larger engine, as wèll as the flywheel, clutch to match up, starter, bellhousing, park brake if attached to trans, starter.
Ed
my 366 is bolted to a sm420. you know where I am so you can come look if that would help.
1959 Chevy 8500 - Spartan 80
366 BBC
Sweet man thanks. Ill be in touch!!
24601
Is something wrong with the 305? Just checking -- maybe we can save you a lot of trouble here...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Rod bearing is shot and its knocking amd i dont really want the v6
That V-6 came in larger versions with the same block, not to discount your interest in the 366.
Ed
