| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | I need to install patch panels on the lower rear of the front fenders of my 56 behind the wheel well. I can weld them, but I also have a glue gun and two-part body adhesive that I bought a while back for a Mustang project and then never used. Any opinions on which way to go? Which is easier and achieves batter looking results? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I dunno, but my buddy who works in a body shop loves the glue, uses it to put bedsides & door skins on all the time. If you are just patching & its not structural I would say go for it. Brian | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | body shops aroud here seem to love it too .... of course they're tryin to make the fastest buck possible on patchin up new cars for insurance companies Bill | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used the glue a few years ago on a Nova we had. Worked great. | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | with the glue all distorition is gone,,I offset flange the panel to be repaired so the repair panel is flush when glued...doc | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | Sounds like the glues have it. I've always welded before, and you're right -- had to deal with some distortion. I think I'll try the glue this time and see. | | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | Is that glue expensive? I have never used it before but I would love to use in on my cowl patch I am planning on doing. I am very afraid of distortion in this area. Is it easy to use? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | It ain't real cheap, the gun is a one time cost-ya grind the area to rough it up & apply. Clamp til set. Couldn't be easier. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Something seems inately wrong with gluing patch panels on. I am unfamiluar with the technique, but my gut tells me no.
I don't even like to overlapine patches when welding (seams), would rather butt my joints, which can't be done with glue. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I'm with you Tom if it ain't done right ,it ain't done right.PERIOD | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | If you guys don't have welding capabilities, the actual welding isn't that expensive. Cut, fit, get everything ready, then take your project to a local body shop. You might get it back the same day if you take it in early. Tell them just weld. Do all the cleanup etc yourselves. I think you will be suprised how inexpensive and fast this part of the job can be done if everything is completely ready to go for them. I'd leave the glue for furniture. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | You would glue a piece of metal on the inside of the panel to get a butt joint. Took an autobody class a few years ago. Most of the newer vehicles on the road today have panels that are glued on.I thought the same thing about glue until I saw it done by a professional. I am not a pro at welding, but not bad either. In certain situations glue is the way to go. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Thats cool, to each his own, but I'm gonna stick to good ol fashioned welded butt joints where you can't even tell its been done. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I have never done the glue thing, but I have a friend who does a ton of body work, and he has a 55 BelAir and tried gluing a right rear quarter panel in, I saw the car two weeks after it was painted at a car show and the glue had allowed the panel to raise higher than the original metal, not far enough to crack the paint, but far enough to have a eyesore of a seam in a otherwise beautiful black paint job. Ive never seen him so angry. Anyway, I would weld it 10 times outta 10 if it were mine, but thats only my $.02
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Old Trucks are welded.New ones are glued made out of plastic,they have more gadgets and seating room than most cars.I do body work all day and I still weld everthing,tried glue once on a quarter,never again.these are my thoughts on glue! :rolleyes: | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | When I worked in the body shop at a Chevy dealership in the late 1970's, GM made a structural cement to bond metal hood braces to the fiberglass hoods on the Brigadier and Bison trucks.This stuff would bond anything. Knowing how well some of the glue's hold, I personally would still weld a metal panel together on a rust repair. That's the way we always did it. Oh No, I sound just like my father did when I was a kid.(ha) 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | We have glue in the body shop...its just expired from sitting on the shelf for 3 years. My boss says the glue is good stuff, just that we can weld, and we know it's going to last that way.
-shrug- | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Gluing is best at 1/25 scale! 1/1 scale should be welded, unless it is new and made of plastic, resin, fiberglass and vinal.  | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | the local bodyshops are all gluing cab corners, etc.. on newer pickups. Not for me, but they love it.
I was lookign at a suzuki sidekick - it had been rolled - they glued on new roof skin - it got rolled again (no surprise there) and the roof held perfectly. Stuff must be strong. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | full outer bead or eventually finish filler will start to crack at the seam. | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Robin 58 Ah welding near the glue releases it! the glue that is!  | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I guess you could use it to stick it in place and do a few quick tac welds around the panel, then weld. | | |
