2 members (Hotrod Lincoln, 1955 1 Series), 231 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#1239069 10/13/2017 3:16 PM
Removing the oil pan on my 235ci. Engine is mounted on the chassis so I'm doing this laying down. All bolts have been removed but it just seems to be glued in place, can't pull it off. I've tried tapping on the sides with a rubber mallet, also I noticed a little access hole in the block that gets you some edge on the lip of the pan, this is just below the Generator area. I tried tapping with a metal rod thru that hole on the lip of the pan, but it just starts to bend the lip of the pan, but the pan isn't coming off. Do I need to really hulk smash thru there or any tips on getting this thing removed? Appreciate the help.
I have used a thin/strong putty knife.
Might just help to know what year your working on. As Tim said a strong putty knife and a hammer. I can’t think of anything holding it other than the PO put some really sticky silicone on it for a gasket sealer.🛠
Thanks Tim! I just did some scraping with a putty knife around that front left corner, got it there to start then was able to put a larger screw driver in the corner and leverage and it just popped off!! Whew, now the fun begins right?
Tim, it's interesting the 2 gaskets at the front and rear of the pan are cork, just like the sides. I see many of the gasket kits they sell today, the sides are still cork, but the front & rear are a black rubber or silicone (those round 180 degree gaskets). You can imagine there is much cork residue left in the recess areas I have to remove before using these new rubber gaskets, any special tools to scrape these out? I've been using a variety of sizes of flat head screw dirvers, they seem to work pretty good but it is slow going.
Look for a scotchbright dist which goes on an angle grinder. Another option is a Norton paint remover disc. They will take the adhesive off without harming the metal.
Thanks Carl! I have a dremel tool, hopefully they have scotchbright bits for that. Also, would it be reasonable to try and burn some of the cork residue off with my small butane torch?
They make the paint removal disks that fit on a hand drill as well. Might be able to make quicker work of it with a bit larger disk than a dremel will handle.
Look up 3M #7772ES
Thanks Kevin!!
