3 members (Paul_WNC, Gdads51, jmoore), 63 guests, and 4 robots.
Topics128,021
Posts1,055,357
Members48,420
#12392 12/27/2004 9:45 PM
I'v got a Stromberg WW on a 55 288. It runs good after it's warm, but I can't get it to start without priming. I rebuilt it but have no idea if I did it correctly. Help!!
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
#12393 12/28/2004 2:23 AM
Is the bowl filling with fuel? (Check to see if it squirts fuel when you pump the accelerator, assuming this carb has a manual pump).
Is the float level set correctly?
If the carb is in good shape then the fuel pump may be losing output or draining back to the tank.
Chevy engines should start easily with just the choke as long as the float bowl contains fresh fuel and the ignition is in good shape.
Paint & Body Shop moderator
#12394 12/28/2004 2:50 AM
It doesn't squirt out in a stream but, kinda dribbles out.
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
#12395 12/28/2004 5:05 AM
Sounds like two things . float adjustment and tha accelator piston needs spreading. Pull the top off and adjust the floaat setting. check the piston on the accelator should fit tight but not too tight.
jbennett
40 burb
#12396 12/28/2004 6:24 AM
Thanks for the info. If I can't find the original instructions how do I set the float?
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
