| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12392 12/27/2004 9:45 PM | Joined: Aug 2003 Posts: 17 New Guy | | New Guy Joined: Aug 2003 Posts: 17 | I'v got a Stromberg WW on a 55 288. It runs good after it's warm, but I can't get it to start without priming. I rebuilt it but have no idea if I did it correctly. Help!!
58 1 ton Napco 59 1/2 ton Napco 58 1/2 ton Napco 55 1 ton 9’ bed 58 3/4 ton stepside 55 LCF boom truck (3) 57 2 tons
#12393 12/28/2004 2:23 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Is the bowl filling with fuel? (Check to see if it squirts fuel when you pump the accelerator, assuming this carb has a manual pump).
Is the float level set correctly?
If the carb is in good shape then the fuel pump may be losing output or draining back to the tank.
Chevy engines should start easily with just the choke as long as the float bowl contains fresh fuel and the ignition is in good shape.
#12394 12/28/2004 2:50 AM | Joined: Aug 2003 Posts: 17 New Guy | | New Guy Joined: Aug 2003 Posts: 17 | It doesn't squirt out in a stream but, kinda dribbles out.
#12395 12/28/2004 5:05 AM | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Sounds like two things . float adjustment and tha accelator piston needs spreading. Pull the top off and adjust the floaat setting. check the piston on the accelator should fit tight but not too tight. jbennett 40 burb | | |
#12396 12/28/2004 6:24 AM | Joined: Aug 2003 Posts: 17 New Guy | | New Guy Joined: Aug 2003 Posts: 17 | Thanks for the info. If I can't find the original instructions how do I set the float?
