4 members (Hawkman, MikeStone1953, 55shaker, Gdads51), 164 guests, and 2 robots.
Topics128,086
Posts1,056,099
Members48,434
#1239124 10/13/2017 10:26 PM
Need a little help please. Tail lights work, directional work, but no brake lights. Have 12 volts to socket, but no light. Cleaned all the contacts, added another ground. Light bulbs check good. Any thoughts on this????
Replace your brake light switch.🛠
Brake light switch works fine.
Crusing in the Passing Lane
Directional filaments are the same ones used for brake lights, unless one has separate lights for each function(rare, not factory). Brake light switch wire needs to run through turn signal switch.
Ed
