1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12389 09/26/2002 11:32 PM | Joined: Sep 2000 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 19 | Heres a question. if i wanted to customize my gauge package. say pull the displays from a scrapped sports car or digital dash from a lumina.... Can I hook the spedometer up so that it works accurately ? Maybe somebody knows and can help me. Thanks..
Turn them Tires, so ya can smoke 'em and choke 'em ![[Linked Image from angelfire.com]](http://www.angelfire.com/ns/2xcapers/images/GMC_910_avatar.gif) Vic... '65 GMC 910
#12390 09/27/2002 12:03 AM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | 910-That stuff's all fly-by-wire. Meaning, there is a sender or sensor for EVERYTHING including the speedo (no old-fashioned cable). If you or an acquaintence are skilled in electronics, you could probably pull it off. You would want to make sure to get ALL of the sensors from the donor car. However, are they going to be compatible with your truck and all of its different mechanical systems? You might just be wiser to buy a premade custom digital cluster from Dakota Digital or one of the other aftermarket suppliers. They are already set up to work with an "old tech" truck and its "old tech" driveline. Best of luck on your project. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
