| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 156 | Evening! I'm going to invest in a digital timing light that can also function as a tachometer. One model boasted "works with almost all 12-volt systems", which got me wondering, would it work with a 6-volt system?
Do I need to buy a timing light that explicitly works with 6 volts? Do you guys have any recommendations for or against a certain brand or model? Digital with tach seem to run around $100, although I saw one model on Amazon for $60, but I need to confirm its features.
Thanks!
DJ '51 Chevy 3104 1/2-ton 216
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | DJ,
I think you should look for one that states 6v & 12v
Post brands and part numbers here and members will help you look for specifications.
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | There's a simple work-around. Pick up a small gel cell 12V such as one that's used on a kid's motorized toy car, and connect the power leads to the timing light to it. Then use the vehicle's #1 spark plug wire to trigger the flash. The timing light doesn't care where it gets its power- - - - -or the high voltage impulse, for that matter.
It's hard to beat a Snap-On MT 1216. Mine has been working on 6V, 12V, and magneto-ignition outboard motors, lawn mowers, etc. for years, using the auxiliary battery trick. It's also got delay-flash and tachometer functions. There are several of them on Ebay right now at bargain prices. Jerry
| | | | | Joined: Feb 2008 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 156 | Thanks guys. Both good ideas. I actually have a spare 12-v car battery (it was lacking in CCAs but still had 12 volts, so I decided to keep it), so I'll probably go that route.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | https://www.stovebolt.com/techtips/timinglight.htmlYou can pull up one of your 12V vehicles close and use it's battery for a one time deal.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | If the light doesn't flash well, try attaching a ground wire between the vehicle body or frame and the 12V timing light battery (-) post. There's no possibility of getting an unwanted 12 volt input anywhere to the vehicle but a common ground would be beneficial. Jerry
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | There's a simple work-around. Pick up a small gel cell 12V such as one that's used on a kid's motorized toy car, and connect the power leads to the timing light to it. Then use the vehicle's #1 spark plug wire to trigger the flash. The timing light doesn't care where it gets its power- - - - -or the high voltage impulse, for that matter.
It's hard to beat a Snap-On MT 1216. Mine has been working on 6V, 12V, and magneto-ignition outboard motors, lawn mowers, etc. for years, using the auxiliary battery trick. It's also got delay-flash and tachometer functions. There are several of them on Ebay right now at bargain prices. Jerry Jerry is that a 1216 or a 1261? Found some 1261 but searching for 1216 i didn't come up with any.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Yep, that's a 1261- - - - -fat-fingered the keyboard! I've been using one for 15 years or so and it does lots of stuff- - - - -checks RPM, timing advance, etc. Snap-On also has good warranty repair service, or at least they used to! They're designed for every day use by professionals. Jerry
