Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Ridgeback, 78buckshot, Oswald, 1 invisible), 101 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#1238699 10/10/2017 5:59 PM
Hi, I'm a new member I have a 1956 gmc 100 short bed that just won its first junior at the aaca in Hershey pa. Going for a senior at next meet,can some one please tell if the hood hinges are cadmium plated or body color, and what color are the springs.my are body color at the moment.some guy at show said the truck is perfect but he thinks the hinges should be cadium plated,he said chevys were cad plated didn't know about gmc. Thanks for any info.
Emanon #1238711 10/10/2017 7:21 PM
Ok, your off to a bad start here. Posting the same question multiple times just because you don’t get an immediate answer is not how you win friends and influence people. Slow your roll, someone will be along to help you within a few hours.
Emanon #1238714 10/10/2017 7:25 PM
what is the question
where is the post
Redryder pix
My Hotrod
Emanon #1238715 10/10/2017 7:37 PM
Post had to be approved. Should be there now.
Sorry, New at this.
Emanon #1239224 10/14/2017 3:53 PM
Z
Z Offline
I got some really nice looking original hinges at the junk yard last week and they appeared to have some sort of galvanized coating.
Emanon #1239299 10/15/2017 1:46 AM
I pulled a hinge off an AD which had never been removed before, and there was what looked like plumber's putty under it which is what GM used to keep rain out of the cab. Once the putty was cleaned off I could see a shiny, metallic silver finish. I have used Rustoleum self-etching primer under Rustoleum metallic silver paint which is a very close duplication of the original finish, which I believe was cadmium plating.
Emanon #1239301 10/15/2017 1:59 AM
Zenwren #1239515 10/16/2017 7:47 PM
Thanks for the info zenwren.
52Carl #1239516 10/16/2017 7:49 PM
Thanks for the information, I believe they should be cadmium plated.
tclederman #1239517 10/16/2017 7:54 PM
Thanks for the info, going to send them out to get cadmium plated for the next aaca senior judging show. Thanks much......
Emanon #1239595 10/17/2017 2:45 AM
Originally Posted by Emanon
some guy at show said the truck is perfect but he thinks the hinges should be cadmium plated,he said chevys were cad plated didn't know about gmc.
That guy was me...I was 99% sure they should be cadmium hinges, but wanted the GMC guys to weigh in.
You have a really nice truck, did you win a trophy?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1240530 10/24/2017 2:15 PM
Hi Mike B, yes I did win first place now going for a senior award, thanks for the info. Sending the hindges out to plated.
