0 members (),
309
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 1 New Guy | | New Guy Joined: Dec 2015 Posts: 1 | Are the wheels on 3/4 ton '60-'66 Chevy trucks 16" or 16.5"? Thanks | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | 15" & 16" 8 lug, 16.5 came out later
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | The GM Heritage center will show you all of the combinations and options. Linked from the LINKS pages or: https://www.gmheritagecenter.com/.I think you will find 15 in was standard. 16 was not atypical. 16.5 as well as BC mentions. Welcome back. HB | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | 16.5s were available starting in 66 | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I can remember tubeless 16.5's on 1 ton rated bread trucks as early as the late 1950's. They were the same profile height as corresponding 15" tube type tires, and could be used interchangeably on dual-wheel rear ends with one 15 and one 16.5 without a height difference. 17.5's matched the height of 16" tube tires. Jerry
