8 members (Wally / Montana, cmayna, 49nut, Hotrod Lincoln, GRNHydra, HandyAndy, Leo, 1 invisible), 128 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#1237538 10/03/2017 1:44 AM
I have a 59 with a sm420, ran in to a guy that has one out of a 52. was wondering if it will fit in mine. It was from a closed drive shaft truck mine is open and has the emerg brake on the back. mine has a lot of noise in second and am wondering if the parts will interchange . price is probably right on the trans.
59chevy36 #1237574 10/03/2017 12:04 PM
Crusing in the Passing Lane
Always good to have a spare, however, probably more work than to just rebuild existing 420. Novak in Salt Lake City has all the parts you will need.
Ed
59chevy36 #1237576 10/03/2017 12:25 PM
Both bolt to the bellhousing the same, all SM240's do.
I believe that you can mix and match output parts and convert one to the other type of driveline, but I have not done it.
They're so cheap and plentiful I'd just find one that actually fits.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
59chevy36 #1238162 10/07/2017 5:19 PM
here is information from Novak's website. Looks like the difference is a weep hole on the 52.
1947-1953:
No ribs on the case
Grooved worm on the input shaft instead of neoprene seal
Synchro rings all differ from each other. 1st-2nd synchro ring is bronze
Weep hole at 6 o'clock on the bearing retainer snout
Six digit casting number on the case, usually like "59xxxx" e.g., 591665.
1954-1963:
Same as previous but uses a neoprene input oil seal
No weep hole at 6 o'clock on the bearing retainer snout
1964-1967: Same as previous except
1st-2nd synchro ring is aluminum and 3rd-4th synchro rings are identical to each other
Seven digit casting number usually like "37xxxxx", "38xxxxx" or "39xxxxx"
1968-1981: Military Con-Diesel version. Features the strongest case and optimized internals. Usually equipped with unique top cover, but can be converted to standard top-shift control.
