1 members (Wally / Montana), 102 guests, and 1 robot.
Topics128,130
Posts1,056,720
Members48,454
#1237993 10/06/2017 5:20 AM
Just wondering, can '50 ho72 DRW hubs fit onto a '73 14bff 3/4 ton axle? Read this is a yes, and of course some places no.
I assume that ho72 hubs can also fit onto a ho52 axle?
1950 3800 dually
First off, on your 1950 1 ton axle the hubs are same single or dual wheel, and yes, same for 3/4 or 1 ton.. The studs are longer for dual wheels.
If you do some searching of this forum and some of the 4x4 forums you can read plenty about swapping parts.
https://www.stovebolt.com/ubbthread.../re-1948-3600-axle-swap.html#Post1019387
https://www.stovebolt.com/ubbthread...6672/Late_model_GM_disc_brake_swap_.html
In your mixing and matching consider that even if the hub can be made to fit, the brake backing plate flange on the axle tube may not be in the right place.
Also know that on newer axles different size brakes and single or dual may have the mounting flanges in different places to suit.
•1952 Chevrolet 3800 pickup
---All pictures---
