2 members (Uncles51, Rexville48), 64 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1237719 10/04/2017 12:56 PM
I have a stock 56 chevy truck with 215 75 15 tires, a guy has some whitewalls for sale that are 8.20 x 15's. I believe an 8.20 x 15 is the same as a 275 60 15. My question is this, will those tires fit on my stock rims? They are quite a bit wider and am worried whether they would rub. Thanks for the help.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
niobrarafun #1237720 10/04/2017 12:59 PM
Crusing in the Passing Lane
Are those antique tires, best to check build date.
Ed
EdPruss #1237721 10/04/2017 1:05 PM
I have no idea, once i know whether they will work, i will start getting the details. He lives about 2 hours from me unfortunately. I'll have to ask for some pics.
I talked to the guy and he said the tires are probably 10 years old, have been inside and have 95% of their tread. I am more worrited that they'll rub, and i would also have to get different rims to fit them on. Thoughts???
Wheel Diameter: 15 in.
Tire Size: 275/60-15
Tire Construction: Radial
Tire Diameter Range: 28-28.99 in.
Tire Diameter: 28.10 in.
Section Width: 10.70 in.
Tread Width: 8.90 in.
Minimum Recommended Wheel Width: 7.50 in.
Maximum Recommended Wheel Width: 9.50 in.
Tire Size: 8.20-15
Tire Diameter Range: 29-29.99 in.
Tire Diameter: 29.91 in.
Section Width: 7.62 in.
Tread Width: 5.60 in.
Minimum Recommended Wheel Width: 6.00 in.
Wow, big difference! Do you think the 8.20 15's would work on stock 1/2 ton rims for a taskforce truck?
Absolutely not- - - -8.20-15's were standard tires for big Buicks, Cadillacs, etc. and they needed a much wider rim. That's also a bias ply designation, not a radial. The sidewall profile would be a lot higher on the 8.20, something like 78% of the tread width, instead of the 60% tread-to sidewall ratio of the 60 series radial.
7.00R15LT work well and look good but are close to rubbing .... I suspect 8.20 would rub the drag link at full turns .... your stock rims should be 6"
