| | | Forums66 Topics128,091 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | I would like to brush on a white or light grey paint and I want the brush strokes to be as dominate as possible. Top this with a sprayed on black, then block sand to expose the highest strokes of the white paint. I imagine a crosshatched patern depending on how I do the brushing. After the sanding, spray on a satin clear coat. Will this work? The paint store guy thought I was nuts when I asked for an additive to thicken the paint and prevent flow. Does anyone have any adivce on the type of paint I might try, how to get the definite brush strokes, what kind of brush to use etc? I want to protect the truck and get an unconventional but smooth, satin look. I know I need to just experiment but maybe someone out there can guide me some. I have it primed in urathane. As always, thanks
All the best, Ted
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | It sounds like you have the finish figured out. To get the brush texture, I would talk to a good house painter. They would know the ins and outs of brush paint flow. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | hey ted i would try a little test on a panel with the paint unthinned .you can see how it lays with a coarse hair paint brush from home depot.the worse thing that could happen is you learn what not to do. tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Sounds like a rat rod project to me!
I would ask a paint store to mix up some of the base coat color on the thick side, then brush it on with a regular run of the mill "tom saywer" paint brush (flat, 3 inch household type). Make sure you get a good one so no bristles are left in your job. It will probably be pretty rough on the brush since it is made for water sol probably. After you apply it, let it get tacky then run the brush thru it again. That'll get you your brush stokes. Try it on another sheet of something first. Then the top coat can be typical can applyed as well as a clear....Haven't done it, but that is the way I'd go.
I restored an airplane dash, and made it look old with those crackle paints and (base one color and top a second). That works awesome so if you are after old and not specifically brush, then you might consider that. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | OH GOD!!!!! PLEASE DONT DO THAT TO A PANEL TRUCK!!! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can get brush strokes with any paint using a "dry brush" effect. Just don't load the brush with much paint, and dab it off the brush with a cloth before you apply it. The paint will be about dry by the time it hits the body and it won't have time to flow out. I wouldn't mess with the mix of the paint or it won't cure right.
Check out model railroader tech tips for good brush and antiquing effects, they have been doing it for years and it works on full scale stuff too.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I was a house painter, you can buy products at your local paint store that is used for oil based paints that will thicken the paint. As far as the brush to use, I would buy a cheap plastic synthetic bristle brush that doesn't have a nice straight cut at the ends. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I am thinking you could spray a thick coat on an area and then hit it with a dry brush while the paint is still wet. You would need to wipe the paint off of the brush often.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | My 2 cents worth.I agree with almost all suggestions here,but will add.Oil paints should use a natural bristle brush,therefore use synthetic,don't load too much paint on the brush,and keep the paint and the room as cold as possible.It will take a long time to dry but I'm sure you will get the finsh you want | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Are ya handpaintin Sanford n son or anything for a $ on the doors ? hehehehe | | |
