| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I have a stock 56 chevy truck with 215 75 15 tires, a guy has some whitewalls for sale that are 8.20 x 15's. I believe an 8.20 x 15 is the same as a 275 60 15. My question is this, will those tires fit on my stock rims? They are quite a bit wider and am worried whether they would rub. Thanks for the help. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Are those antique tires, best to check build date.
Ed
| | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I have no idea, once i know whether they will work, i will start getting the details. He lives about 2 hours from me unfortunately. I'll have to ask for some pics. | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I talked to the guy and he said the tires are probably 10 years old, have been inside and have 95% of their tread. I am more worrited that they'll rub, and i would also have to get different rims to fit them on. Thoughts??? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wheel Diameter: 15 in. Tire Size: 275/60-15 Tire Construction: Radial Tire Diameter Range: 28-28.99 in. Tire Diameter: 28.10 in. Section Width: 10.70 in. Tread Width: 8.90 in. Minimum Recommended Wheel Width: 7.50 in. Maximum Recommended Wheel Width: 9.50 in.
Wheel Diameter: 15 in. Tire Size: 8.20-15 Tire Construction: Radial Tire Diameter Range: 29-29.99 in. Tire Diameter: 29.91 in. Section Width: 7.62 in. Tread Width: 5.60 in. Minimum Recommended Wheel Width: 6.00 in. | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Wow, big difference! Do you think the 8.20 15's would work on stock 1/2 ton rims for a taskforce truck? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Do you think the 8.20 15's would work on stock 1/2 ton rims for a taskforce truck? Absolutely not- - - -8.20-15's were standard tires for big Buicks, Cadillacs, etc. and they needed a much wider rim. That's also a bias ply designation, not a radial. The sidewall profile would be a lot higher on the 8.20, something like 78% of the tread width, instead of the 60% tread-to sidewall ratio of the 60 series radial. Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 7.00R15LT work well and look good but are close to rubbing .... I suspect 8.20 would rub the drag link at full turns .... your stock rims should be 6" Bill | | |
