1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I have a 59 with a sm420, ran in to a guy that has one out of a 52. was wondering if it will fit in mine. It was from a closed drive shaft truck mine is open and has the emerg brake on the back. mine has a lot of noise in second and am wondering if the parts will interchange . price is probably right on the trans. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Always good to have a spare, however, probably more work than to just rebuild existing 420. Novak in Salt Lake City has all the parts you will need.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Both bolt to the bellhousing the same, all SM240's do.
I believe that you can mix and match output parts and convert one to the other type of driveline, but I have not done it.
They're so cheap and plentiful I'd just find one that actually fits.
Grigg | | | | | Joined: Aug 2017 Posts: 1 New Guy | | New Guy Joined: Aug 2017 Posts: 1 | here is information from Novak's website. Looks like the difference is a weep hole on the 52.
1947-1953: No ribs on the case Grooved worm on the input shaft instead of neoprene seal Synchro rings all differ from each other. 1st-2nd synchro ring is bronze Weep hole at 6 o'clock on the bearing retainer snout Six digit casting number on the case, usually like "59xxxx" e.g., 591665.
1954-1963: Same as previous but uses a neoprene input oil seal No weep hole at 6 o'clock on the bearing retainer snout
1964-1967: Same as previous except 1st-2nd synchro ring is aluminum and 3rd-4th synchro rings are identical to each other Seven digit casting number usually like "37xxxxx", "38xxxxx" or "39xxxxx"
1968-1981: Military Con-Diesel version. Features the strongest case and optimized internals. Usually equipped with unique top cover, but can be converted to standard top-shift control. | | |
