| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 |
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jb, I use this simple technique. You need a vacuum gauge.Other's might post the slight correction that could be made to this timing adjustment. I have used this technique for many years on all my old 6-cylinder GMC/Chevrolet engines. There are timing marks on flywheels. They usually have a TDC/UDC mark (usually a BB/ball embedded in the flywheel at Top Dead Center / Upper Dead Center), and they usually also have a timing mark (different degrees of TDC, depending on engine and year). I think my 1959 and 1960 261s did not have an embedded ball, they had marks. You can do "static" timing or dynamic timing (timing light) with those marks (hoping that you have the correct flywheel for your engine). | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Whether I use Tim's method, or use a timing light, I don't call it good enough until I drive it under load to listen for the telltale light ping. This can be done up a hill in 3rd gear when 2nd gear would have been a better choice. I then advance it a degree at a time from there until the ping is gone. If you get greedy and advance it too much past the ping position, you will loose power. Carl
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Carl, I have to disagree just a little-- - - -if it's pinging, it's advanced too far already. When you hear the detonation, retard- - - -don't advance the timing a degree or two at a time. Jerry
