On our 66 Burb, I was putting in the new fuel lines that run down the frame, and where it splits at the crossmember is a question. I assume that the chunk of hose goes thru the crossmember and connects to the fuel line on each side, but the lines seem to match the frame and line up better if I join it right behind the crossmember. Which location is correct? Obviously I did not have a pre picture of this area, no matter how many you take, it's never what you need. I believe the break was for using the front piece on pickup trucks with the tank in the cab, so the crossmember location is not necessarily an issue I guess. Thank you for your help.
