5 members (Dusty53, fonz8261, Stovebolt48, 1955 1 Series, DHedrick), 308 guests, and 6 robots.
Topics128,158
Posts1,057,023
Members48,460
I am still putting final touches on the engine installation - '55 235 with single barrel Rochester with a low pressure electric fuel pump added near the fuel tank. Turned on the ignition to run the pump for a moment and then pumped the throttle a few times to put fuel into the carb throat. That was when I noticed that I had some fuel running down the outside of the carb from the ends of the throttle shaft. Assuming the carb is equipped with a throttle pump, is that an issue that clears up after the engine is started and running? I don't really need an engine fire before the truck is even street legal.
Bob
BobS46
Fuel leaking at the ends of the throttle shaft holes usually indicates that fuel is getting past the float needle/seat. Dirt, or float is contacting side of carb.
Thanks. One more thing to tear into, again.
BobS46
Get yourself about an 18 inch screwdriver. Use the handle to tap on the side of your carburetor. Seems to work best for me, when the engine is not running. Could be anything in there, that is causing it to stick. Since we can't buy Ethanol free gas, here in Arizona. Then, we have the heat. I wonder if the Ethanol has a tendency to crystalize. I had it happen to me a couple of times. I have a Carter YF on my 53 3100. I took the advice of a friend, and dumped some Stabil Marine, in my tank. It is supposed to combat the Ethanol. It is a problem for boaters as well. So far, it hasn't happened again. Just something to consider. Good luck with it.
Rugo
Steve Rugg
53 3100
Yep, I'd try tapping the float bowl area. If that fails, you could pull the top and check the set level on the float and make SURE no trash between the needle and seat. But my money is the electric pump is providing too much pressure. It's pretty easy to slip a fuel pressure gauge inline and make sure pressure is between 2 and 4 psi.
This is the best video I've seen on Rochester B's and flooding issues (which is what you have).
Good Luck, Ron
RonR
1970 340 Duster
1964 CJ5
Bob,
What is the pressure rating on your low-pressure fuel pump?
Tim,
Thanks for the reply. FINALLY found the invoice that had the part number - K&N 0402. 4-7 psi, 32 gph. I believe that it was suggested by someone on the forum.
Just a point of information, the pump is tied directly to the ignition, relying on the needle valve to halt fuel flow. I just found http://devestechnet.com/Services/FuelSystemUpgrades which shows a device that will power the pump for xx seconds after the ignition is turned on; combined with an oil pressure switch, it might provide a good alternative.
Bob
BobS46
