| | | Forums66 Topics128,277 Posts1,058,443 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 75 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 75 | Does anyone know where you can find the u-bolts that hold the rear axle to the control arms on a 1963 c-10? I've tried every part supplier I know without success. Mine might be reusable, but I figured since they hold up the entire rear of the truck I should install new ones. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look around for a shop that does spring repair/rebuilds or specializes in rear ends, if they don't have a match on the shelf they can make you some
| | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | You might try r and s spring works in bladensburg md on your next trip thru D.C. They are remarkable in what they have in stock wrt suspensions. Maybe other shops to consider in your area. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | LMC Truck has them online. Item number 21 at this LINKI hope this helps. | | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | NAPA and Auto Zone have em as well as Classic Truck Parts of America | | |
