4 members (NJC, Oswald, 2 invisible),
132
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | Hello fellow Chevy owners. I just put a Holley 4brl 650 on my 65' C20 'MadDog' because i had a edelbrock that was trash. I have a SBC 350 with turbo 400at. I am now getting a misfire sounding like its right in the dash close to the distributor. Im running a distributor with points still and have been told that I need to go MSD. Anyways it is missing and almost sounds like it running on 7 cylinders instead of 8. Any help would be appreciated. MadDog
Darren D'Ambrogi
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It doesn't sound like a condition with the carb. Make sure you dont have plug wire pulled off or 2 wires crossed. A bad vacuum leak can act like a missfire. Check the vacuum connections at the outlet in the manifold behind the carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Holley VS Edelbrock- - - - - -that's like getting beaten to death with a stick or a rock. Anything other than the original equipment Quadrajet is a big step backwards. Was the engine missing before you swapped carbs? Try using the gas from an unlit Propane torch to check for vacuum leaks. Turn the gas on and move the nozzle around all the gasket sealing surfaces. If it gets picked up by a vacuum leak the engine will smooth out or speed up. It's also easy to swap plug wires between cylinders 5 and 7. They're side by side on the distributor cap. Jerry
| | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | Thanks for your reply. I checked all plugs and wires and they are good. I also haven't found any vacuum leeks either. Still scratchin my head!
Darren D'Ambrogi
| | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | Thanks for the reply. It was not missing this bad before the swap but yes when I laid into the gass it would usually backfire and miss along with massive power loss. It would almost feel like it was starving for fuel type of feeling. Now if i step on it either from a stop or in any gear it misses and not responding like a V8 should at all. I will have to try the propane thing but I have sprayed carb cleaner with it running all over and didnt see any leaks when I did that.
Darren D'Ambrogi
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Check your vacuum advance to see if it’s working properly.ðŸ›
| | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | Thanks for the reply. I have checked the Advance. I took the distributor cap off and disconnected the vac line into carb and sucked on it and it moved the mechanisms inside the distributor just fine and had a strong suction. This is a mechanic trick that the original owner that is 92 told me to do. He was a mechanic his whole life and was the one i bought the truck from. So I have been looking at the MSD Ready to Run distributors and may just have to go with new school meets old school!
Darren D'Ambrogi
| | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | Dose anybody have recommendation on HEI ready to run distributors? And what is your opinion on them compared to original points distributor?
Darren D'Ambrogi
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | MadDog, start a new thread. HEI has nothing to do with a Holley Carb issue. By keeping topics separate it makes for easier searching for those who follow along behind us. ThanksðŸ›
Darren D'Ambrogi
| | | | | Joined: Sep 2017 Posts: 12 New Guy | | New Guy Joined: Sep 2017 Posts: 12 | So its been over a month since I have even touched good old MadDog. It sucks but been super busy off getting married and stuff. Anyways really want to get him running right and am at a loss. Are any of you Chevy owners close by in southern California? If so let me know and I would love some help getting him back out and screaming down the streets. Thanks!
Darren D'Ambrogi
