0 members (),
135
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 50 'Bolter | | 'Bolter Joined: May 2017 Posts: 50 | I have a feeling I know the answer to this one, but is it safe to lift the front of a half ton by placing the jack in the center of the axle? I've done it a few times on parts trucks and it doesn't seem to hurt anything and sure makes it easy to slide a couple jack stands under the spring pads. I just don't want to bend my axle. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have done it many times; but, I soon thereafter put jack-stands under both sides of the axle, and then lower the jack. Let's see if others post that is a no-no.  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think it depends on the weight of the truck and the relative size of the front axle beam. Some trucks the axle looks small and fragile, so jack each side. Some trucks have real beefy I-beam axles and don't look like they'd bend easy, so jacking in the middle seems safe. Though fully loaded may still opt to jack separately.
Use a little guesstimation and common sense.
Grigg | | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | IMO, you're not going to bend the axle on a 1/2 ton truck. Even if it did deflect a bit, you won't exceed the elastic limit of the steel. There's a story in here. I've bent the axle on a Ford Model AA when we got it stuck in the mud when I was a kid. But of course, we tied the chain to the center of the axle, and my buddy used the back up and jerk method, then kept yelling at me to turn the wheels straight. I looked out the left side and the wheel was straight, but he was looking out the right side mirror at the wheel that was toed-in about 30 degrees. We both got out and discovered the center of the axle was about a foot closer to the front of the truck than it should have been.  Another story while I'm at at (sorry). I had a flat on the rear of my F250, and pulled into a WalMart shop to get it fixed. I stood there and watched the jack monkey try and jack it up from the pumpkin while it was loaded at max GVW with a camper. I told him to jack it at the spring mounts, so he tried to reach up to the front spring mount at the frame - way higher than his jack would reach.  AT that point, I drove it out of the shop.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | That's how I do it but the guys here will tell you that I have no idea what I'm doing so.......
Seriously, I have done it that way several times and I find jacking it up in the center makes it harder for the truck to slip off the jack or stands rather than trying to get one side up at a time. Just feels safer.
But..... let some of the other guys confirm this as I AM NOT an expert.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | FWIW I always jack from the center if I'm going to be working on both sides of my '38. I put a jack stand under the axle of the side I have the wheel off of for safety but I usually leave the weight on the jack. I'm not an engineer but I think the axle is more than strong enough to take the load.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I try to always jack one side at a time and get a jackstand directly under the spring, or as close as possible. If you have the capability/tools, lift on the frame or at least get it high enough to put stands under the frame. I end up with two tall stands under the frame and two more under the axle. And another thought, I don't pull or tow on the axle. I figure out a way to pull on the frame. I saw an axle bend once, under some very extreme conditions and under the supervision of some very questionably skilled characters, so it is possible to bend an axle. Also if you look int he manuals, bending the axle is the way to adjust the alignment.
My way takes longer and requires more work and crawling around on the garage floor or driveway.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | I've not heard of anyone damaging an axle in this way. But, you could use a piece of heavy angle or channel on the jack head to distribute the weight and eliminate any concerns.
1955 Chevy (1st Series) 3600
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The axle is designed to hold the weight of the truck, probably to at least 2G.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
