| | | Forums66 Topics128,062 Posts1,055,845 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I had to remove a brass fitting that adapted my engine block drain hole to my petcock. It looks like it had been sitting in acid - the unused inside threads were smooth and the end that was threaded into the block was missing a significant amount of material. Does any one know what might be going on?
Bob
BobS46
| | | | | Joined: May 2015 Posts: 11,045 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,045 | If this is the water jacket drain, then it could be that your coolant has gone acidic. Ethylene Glycol can do that under certain circumstances when the corrosion inhibitors are depleted and the pH drops to the acidic range.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I have never heard anything about this. Can you tell me more? The drain I am talking about - lower, rear corner of the block, driver side - sounds like the same one you are talking about.
Bob
BobS46
