4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
I had to remove a brass fitting that adapted my engine block drain hole to my petcock. It looks like it had been sitting in acid - the unused inside threads were smooth and the end that was threaded into the block was missing a significant amount of material. Does any one know what might be going on?
Bob
BobS46
If this is the water jacket drain, then it could be that your coolant has gone acidic. Ethylene Glycol can do that under certain circumstances when the corrosion inhibitors are depleted and the pH drops to the acidic range.
I have never heard anything about this. Can you tell me more? The drain I am talking about - lower, rear corner of the block, driver side - sounds like the same one you are talking about.
Bob
BobS46
