2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | My truck started as a 46 1/2T truck. The radiator appeared to have a non-pressurized cap. Don't know if that was correct. I now have a 1955 235 engine installed and have gone to a new after market radiator (supposedly designed for the 46 truck) and came with a pressurized cap. What is correct - what do I need - do I have a problem?
Bob
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely, the 1946 cooling system was non-pressurized.
That 1955 235 would have had a 4 psi pressure cap on the radiator.
Does the aftermarket radiator/cap have a pressure rating?
If you have a heater, it should be able to take 4 psi.
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | The only thing I find on the cap is "0.9" stamped into the metal. Does not indicate psi, pascals, or furlongs per fortnight.
BobS46
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | That's a "0.9 BAR" cap which converts to 13 PSI. The radiator is probably rated for that kind of pressure, but you would need to get an ORM heater recored with a modern replacement if you intend to run that much pressure. Every pound of pressure raises the boiling point of the coolant 3 degrees, so a 13# cap would let the coolant go to 251 degrees before it boils. A stovebolt engine doesn't need to run that hot unless you're running air conditioning in a traffic jam, and even then it's a bad idea. A 7# cap should be plenty, which raises the boiling point to 233 degrees. Jerry
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks a lot, guys. Learned a little today.
BobS46
