4 members (Otto Skorzeny, Phak1, Gdads51, Ponchogl), 131 guests, and 3 robots.
Topics128,272
Posts1,058,316
Members48,485
#1236240 09/24/2017 7:18 PM
1953 1/2 ton . I am trying to do the universal ball adjustment and have installed the four supplied shims but it is tight as a drum. I did do some light sanding on the ball and it seems smooth. Do you guys put any oil on the ball for the adjustment? Thanks.
Here is a link to the factory instructions.
The adjustment needs to be made without the tapered seal first, once the seal is installed it can be quite tight to move.
My Blog
No cork seal when you do the adjustment - right?
The manual says to start with 4 shims, and to add/subtract as needed. Unfortunately, most seal kits only come with 4 shims.
Wait to hear from others, but you might need more shims.
Oil (or, light grease) on the ball is OK.
Yes, I knew to leave the cork seal out. Guess I'll try to lube the ball. Thanks tclederman!.
After you determined the number of shims, then
The shop manual, listed under Transmission Installation,
line # 5, has the "How to" install cork & shims.
Recommends a graphite grease,
and provides torque specs, too.
-Tom
1950 Chevy 3100 w/ 1956 235
It would be nice if the vendors included a few more shims in the kits. I guess I'll have to drop 20 more bucks to buy another kit. There actually was a fifth shim in the kit and it was thicker but the holes don't line up?!
It is not that hard to make a few gaskets using an original as a pattern.
My Blog
