7 members (Guitplayer, FAST55, Leo, Oldcaliforniakid, lc_btv, MikeE, Jay R),
83
Mod | | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Well Summers over and winter will be here sooner than you know it. What do you guys do to prepare your trucks for winter storage?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Change the oil and filter, and run the engine until it has warmed up.
Put the appropriate amount of Stabil in the gas tank.
Depending on the type of battery, maybe put it on an automatic battery maintainer? I do nothing with my 6v Optima batteries.
Check the air pressure in the tires? I grease my truck after hibernation, but it could be done before? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | What do you guys do to prepare your trucks for winter storage? Just fill the gas tank. | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | That's when my truck gets the most usage. If it's pouring down rain, I leave the bike in the garage and take the truck. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | My old suburban has so many holes in it, I might as well be riding a motorcycle in the rain.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same as Leo......Just keep the gas tank full with a stabilizer, but I treat the fuel at ever fill up with Stabil anyway. Don't use a battery maintainer either. Old blue sat since last fall and I just cranked her up last week for the first time. Farm & Fleet 6v battery quite old but no problem starting even after that long nap....and did I mention.....had a full tank of that year old E10 in her also. I just ran the last of it out this morning and and filled up with some fresh 2017 petrol. I have, for the past 12 years run only Shell Rotella T 15w-40, summer and winter. Only drive her when the weather is dry, can be cold but must be dry. I think the majority of the problems that people blame bad fuel, bad batteries, bad oil for, can be traced back to poor engine condition, poor maintenance, poor electrical connections. When new, these trucks were reliable and driven in every imaginable weather condition. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Make sure to have a few mouse traps that get checked frequently for furry friends.
Ed
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Storage, I don't use any stinking storage. I drive it on a semi-regular basis.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Drive mine year round. No heater in the '48 Burb, just put on a coat. The '62 C-10 has a heater I assume works. Need to check it out. I make sure the antifreeze is good because they both set outside all the time.ðŸ›
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Wait just a minute. Let me be sure that I understand this correctly.
Am I to believe that everybody does not have a heated & cooled shop/garage? What the.........??
Mike
Mike
1951 3100 5 window
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Don't forget to check the coolant mix to insure it's good to a temperature BELOW your local low winter temps. Mike B  | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | All great advice -- Also be sure to visit our Tech Tips section (use the handy menu bar at the top of the page  ) because there's a very handy article there regarding Winterizing your truckWho knows, there might be other information there you find useful or interesting (or ... gasp ... BOTH!!) And yes, my shop is heated and cooled -- It is heated quite nicely in the summer and stays very cool in the winter.   John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2013 Posts: 613 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 613 | Now that was a good one John. You caught me till I read further!! I did chuckle a little!! Take care, Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, ya got me goin' also John. Had that sinking feeling of jealousy about that "heated and cooled" shop...........till I finished the sentence that is. I'm in the process of converting from propane in the house and wood burner in the barn to Natural Gas that was run out our way last winter. House is up and running now, so the barn is next on the list. Got it plumbed in from the house, under the 60 foot drive and out to the barn this weekend and will be working on over head piping for the 80 foot length of the building this week. Not gonna live with another air conditioned winter in the shop. DG
| | | | | Joined: Oct 2017 Posts: 2 Moderated | | Moderated Joined: Oct 2017 Posts: 2 | You really should change the oil BEFORE storage. The old oil has 'acids/contaminates' in it, which are not good to let sit in the engine all Winter.
Sta-bil in the Full gas tank.
Battery maintainer.
Wax and cover.
Scott 1953 Chevy 3100
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | If you know for certain you won't be driving it again until things thaw out next spring, I'd go ahead and put it up on jack stands to avoid having flat spots on the tires.
Be certain to disconnect the positive cable from the battery to assure no battery drain and/or accidental fire.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | What is this "Winter Storage" you speak of? Oh, that.
Seriously, If non-ethanol contaminated gasoline is available, I strongly suggest having only that in the tank for long term storage. If that's not possible, last thing after all the final prep is done is to squeeze off a rubber portion of the fuel line while the engine is running to ensure no ethanol gas is in the carb to do mischief over the winter.
Ron
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Windyville, you need to winterize yourself and keep driving your truck.
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Ha! I can't drive it very much till my leaky transmission is fixed. Sounds like that may be a longish job. I may freeze to death figuring out how to get the seals replaced.
| | | | | Joined: Mar 2017 Posts: 18 New Guy | | New Guy Joined: Mar 2017 Posts: 18 | LOL In Phoenix AZ, just the opposite...how to SUMMERIZE! And given the current trend,the only comfortable driving is Novenber trough april.I dont even need a choke! | | |
