0 members (),
106
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 6 New Guy | | New Guy Joined: Sep 2017 Posts: 6 | Bought both oiler lines only to notice the oil passage through them was very small. The copper lines that was on it had at least 1/4 inside for oil passage. Not really sure if I want to put these on with such small passages. All companies are selling these same two lines. Does anybody know if this is correct? And why so small of a passage? pressure over volume. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Not really sure if I want to put these on with such small passages. The by-pass oil filter lines had a very small internal diameter. And, the size of the inlet hole is usually the limiting factor. So, yes, the internal diameter could/should be small (but does not have to be, if the inlet hole is small). | | | | | Joined: Sep 2017 Posts: 6 New Guy | | New Guy Joined: Sep 2017 Posts: 6 | thank you. I thought with such a small inlet, it would be easy to plug up. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Regardless of the internal diameter of the lines, oil flow is controlled by a 1/16" orfice built into the filter canister standpipe. You could have a 1" diameter line, and it still wouldn't flow any more oil. As long as the hole in the flex line is at least 1/16" you're good to go. Jerry
