1 members (frogfarmer), 116 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#1235925 09/22/2017 2:48 AM
Bought both oiler lines only to notice the oil passage through them was very small. The copper lines that was on it had at least 1/4 inside for oil passage. Not really sure if I want to put these on with such small passages. All companies are selling these same two lines. Does anybody know if this is correct? And why so small of a passage? pressure over volume.
Quote
The by-pass oil filter lines had a very small internal diameter. And, the size of the inlet hole is usually the limiting factor.
So, yes, the internal diameter could/should be small (but does not have to be, if the inlet hole is small).
thank you. I thought with such a small inlet, it would be easy to plug up.
Regardless of the internal diameter of the lines, oil flow is controlled by a 1/16" orfice built into the filter canister standpipe. You could have a 1" diameter line, and it still wouldn't flow any more oil. As long as the hole in the flex line is at least 1/16" you're good to go.
