1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
Thanks for the help on the last question - found the rubber bumper at Jim Carter.
Question - the accelerator pedal pivots at the bottom end, with a pin the goes through a yoke attached to the toe board and a matching yoke attached to the pedal. How can I find a replacement for this pin?
Bob
BobS46
I seem to recall using a nail about 55 years ago when I had one rust out. Not concourse quality but it got me around.🛠
If you don't decide to opt for the non con-concourse approved nail, you may want to take a trip to your local True Value or Ace Hardware. I live in Gilbert Arizona. We have a number of them around us. I find almost every kind of fastener or special sized part, for my 53 3100 there. Just a thought. Hope this helps.
Rugo
Steve Rugg
53 3100
Thanks Steve - that is sort of what I did. I had a 7" 5/16 bolt, threaded only 1' on the end - perfect fit to the holes in the pedal and toe board. Ground one side of the hex head flat to the bolt shaft so that it would fit up under the pedal. Then the hard part - drilling a hole through the shaft for a cotter pin. Cut off the excess length and works great.
And yes, we even have an Ace WAY down south of you in Hereford, AZ. This truck has led my knowing where every fastener in there inventory is located.
Bob
BobS46
That might not be concourse correct either. But, it does sound like the best way to go for your situation. Glad you got it fixed and are back on the road. If you ever find yourself in the Gilbert area, please look me up. Would like to meet you and talk AD trucks.
Rugo
Steve Rugg
53 3100
The pin comes with any new gas pedal ($14.00). Perhaps they can sell you the pin separately???
~ Dave
What year, Bob?
1946?
Thanks, Dave. I clearly bought mine from the wrong source.
Bob
BobS46
Moderated by  ndkid275, Phak1
