7 members (papas52, klhansen, Shade Baby, 1955 1 Series, Still At It, Bill Hanlon, 1 invisible),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | My toe board has a rectangular depression about 1.5" wide by 0.5" high about 2" below the steering column and clutch pedal. It also has 2 holes in it. Can anyone tell me what goes here?
Also, further down, near the bottom edge, is a 5" pressed "ridge", about 1/2" high. On the back side of this are two strips of metal that look like they retain something in the depression of this ridge. What is this all about?
Other wise, my build is going great. Later this week my fuel tank will be installed for the second time - it had a small accident in the tank well. All four wheels/tires are on. May have clutch/throttle linkage under control. Engine cooling may possibly be figured out. There is a chance that I can get it to the show next month in the "under construction" category, If I can find a trailer - it is about as street legal as Sean Spicer's podium.
Bob
BobS46
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | My toe board has a rectangular depression about 1.5" wide by 0.5" high about 2" below the steering column and clutch pedal. It also has 2 holes in it. Can anyone tell me what goes here? A rubber block for the clutch pedal to contact when you let off the clutch.
Also, further down, near the bottom edge, is a 5" pressed "ridge", about 1/2" high. On the back side of this are two strips of metal that look like they retain something in the depression of this ridge. What is this all about?Not sure just reinforcement for the kick board I think. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Yes the depressed area is for a rubber cushion for the clutch pedal. The little metal strips are to hold the dimmer switch wires away from the clutch and brake pedals. | | |
