6 members (Stan 58, 46 Texaco, RoadsScholar, Otto Skorzeny, Peggy M, 1 invisible), 127 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#123551 12/13/2006 5:58 PM
What do you guys recommend for the " hinge wire " at the connection of upper hood to side hood ?
Is corrosion an issue ?
1940 Chevy KC 1/2-Ton
#123552 12/16/2006 4:59 PM
Wish I could answer, but haven't gotten mine apart yet. Did you want to know what was in there originally or some good ideas on what to replace it with??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#123553 12/17/2006 9:26 PM
My truck is rodded - not stock. Looking for best type of wire / rod to act as a hinge. Doesn't need to be " original "
#123554 02/26/2007 3:12 AM
Apprentice
Apprentice
britcon, I use a 3/16 inch brass rod, with a light coat of white lubricant.
Sorry it took so long to add a reply, must have missed this one.
Jim
Jim
#123555 02/26/2007 11:30 PM
Thanks Jim....I ended up using stainless steel rod with a little white grease.
