2 members (55shaker, Jon G),
79
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | What do you guys recommend for the " hinge wire " at the connection of upper hood to side hood ? Is corrosion an issue ? Thanks | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Wish I could answer, but haven't gotten mine apart yet. Did you want to know what was in there originally or some good ideas on what to replace it with?? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | My truck is rodded - not stock. Looking for best type of wire / rod to act as a hinge. Doesn't need to be " original " Thanks | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | britcon, I use a 3/16 inch brass rod, with a light coat of white lubricant.
Sorry it took so long to add a reply, must have missed this one.
Jim
Jim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Thanks Jim....I ended up using stainless steel rod with a little white grease. | | |
