1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1234222 09/11/2017 6:05 AM
Hi Folks,
How does one go about removing the linkage arms from the wiper arms bearing mount? I would link to remove them so I can sand and paint them. Not sure how to do it without damaging the pins that hold it all together?
thanks
skipper
Ex Hall Monitor
Ex Hall Monitor
The year of your truck?
As Tiny says, post your year, model of truck. Remember to do this every time you start a thread. If you will go back and edit your profile to include your truck description it will help when you forget to tell us in your thread. Help us help you. I'm sure your answer will be along shortly. drive
It is a 1950 1/2 ton.
They originally were held in place by small retainer clips which has a tiny coil spring between them.
Once you remove that, the transmission (that is what GM and the vendors call them) ends should push right out. Sometimes they are snug due to the old hard grommets.
Perhaps I did not explain it well enough. I mean the ends of the arms that connect to the part that the wiper arms connect to. This is part goes through the fire wall. They are held on with some kind of clip?
Ex Hall Monitor
Ex Hall Monitor
Don't know when they stopped but many used the clip shown below to retain the rods at the pivot. It may or may not be relevant to the '50.
<CLICK>
Yes, I see that the spring clips holds the grommeted end of the arm to the transmission. I am speaking of the other end. The end that attaches to the splined rod that the wiper arms/blades attach to. Who does one remove the arms from the rod without breaking things?
