1 members (klhansen),
98
0
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi Folks,
How does one go about removing the linkage arms from the wiper arms bearing mount? I would link to remove them so I can sand and paint them. Not sure how to do it without damaging the pins that hold it all together? thanks skipper | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | As Tiny says, post your year, model of truck. Remember to do this every time you start a thread. If you will go back and edit your profile to include your truck description it will help when you forget to tell us in your thread. Help us help you. I'm sure your answer will be along shortly.
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | They originally were held in place by small retainer clips which has a tiny coil spring between them. Once you remove that, the transmission (that is what GM and the vendors call them) ends should push right out. Sometimes they are snug due to the old hard grommets.
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Perhaps I did not explain it well enough. I mean the ends of the arms that connect to the part that the wiper arms connect to. This is part goes through the fire wall. They are held on with some kind of clip? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Don't know when they stopped but many used the clip shown below to retain the rods at the pivot. It may or may not be relevant to the '50. <CLICK>
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Yes, I see that the spring clips holds the grommeted end of the arm to the transmission. I am speaking of the other end. The end that attaches to the splined rod that the wiper arms/blades attach to. Who does one remove the arms from the rod without breaking things? | | |
