5 members (rfs56trk, JW51, Bill Hanlon, Cosmo, 1 invisible), 105 guests, and 3 robots.
Topics128,080
Posts1,055,956
Members48,430
#1235346 09/19/2017 12:18 AM
J Online: Content
I invested in a small hand vacuum pump/brake bleeder. Just so I'm certain....if the advance is functional, I should be able to move the distributor with it, right? It doesnt move.
Is there anything specific year to year with these vac advance units? The parts listings seem to be by a group of years but they all basically look the same.
Reading old threads, it looks like maybe car and truck advance are different? Have a 1962 engine in a 1951 truck but no clue where the distributor came from.
1951 3100
JW51 #1235353 09/19/2017 12:45 AM
The different part-numbers/years for 216/235/261 vacuum advance units might their angle from the block. The angle was different with different engine mounts (I think) - car and truck.
Pre '68 Dave might comment/correct/confirm this?
JW51 #1235362 09/19/2017 1:12 AM
J Online: Content
I figure I will run a new line anyway. So is the angle just a cosmetic thing or is it specific to the distributor?
1951 3100
JW51 #1235371 09/19/2017 1:35 AM
The distributor must move when vacuum is applied to the vacuum advance.
If it doesn't either the distributor is tight in the block(O ring used on housing is one example of a problem), or the advance diagram has a hole in it.
There were a number of vacuum advance units produced by Chevrolet through the years.
An obvious difference was the mounting angle of some to clear the side mounts(passenger car only).
There were also different advance rate for different applications(controlled by the internal spring rate).
Distributor part numbers by year.
My Blog
JW51 #1235372 09/19/2017 1:37 AM
Is will make no functional difference.
It was specific to the engine mounts, I think. I am using a 1954 vacuum advance unit on a 1960 261 distributor.
JW51 #1235377 09/19/2017 1:47 AM
J Online: Content
Is the 1954 one set up to where the line runs parallel to the block?
1951 3100
JW51 #1235408 09/19/2017 6:09 AM
All trucks ran parallel to the block.
Only 1952-54 and 1958-62 passenger cars had a vacuum advance that angled away from the block to clear the side mounts used in those years.
My Blog
JW51 #1235428 09/19/2017 12:31 PM
J Online: Content
Thanks. One more thing....
The existing steel line is male flare at the advance connection and a female compression fitting at the connection to carb. (Carb port has a male to male in it)
Is that the normal way of doing that?
1951 3100
JW51 #1235430 09/19/2017 12:46 PM
JW51 #1235446 09/19/2017 1:49 PM
J Online: Content
Wow. Not sure I could justify making my own for that price. Have you bought that line from them, before?
1951 3100
JW51 #1235449 09/19/2017 2:02 PM
No, they had the clearest photo I could find (and a good price).
I usually buy from ClassicParts.com or Jim Carter or Chevs of the 40s (in that order, after checking total cost, including shipping). All are listed here in Links.
JW51 #1235524 09/19/2017 10:34 PM
J Online: Content
The price is way cheaper than anything else I've seen. Might be worth a shot.
1951 3100
JW51 #1235672 09/20/2017 6:23 PM
What's the shipping cost? A line that size and shape is going to require some pretty creative packaging.
Yep - around $20 shipping
Other places are around $20 (or more) for the non-stainless line, plus around $15 for shipping.
J Online: Content
Progress!
Spent 20 minutes with the Napa guy today searching for a vac advance. They use actual books to help you find parts, but we still struck out.
Got to thinking there might be one on a couple spare engines in the shed "out back." What looks like a raccoon turd in the attached pic is an actual, functioning vacuum advance as verified by my handy new vacuum pump.
All I have to do now is make it look less like a raccoon turd. Beats spending $40+ for one of questionable origin on eBay.
1951 3100
JW51 #1235736 09/21/2017 1:42 AM
It is absolutely amazing to me how many of these ancient vacuum advance units are still good. I haven't run into a bad original one yet. I have heard about complaints with the reproduction ones not lasting.
JW51 #1235738 09/21/2017 1:51 AM
J Online: Content
I did test three ancient ones that were bad. Two of the nastiest ones actually work. One of them was covered in rust and still worked.
Reckon I should be careful and not soak this thing in solvent? Imagine that would be hard on the diaphragm?
1951 3100
JW51 #1235845 09/21/2017 4:42 PM
J Online: Content
Would soaking this nasty thing in diesel be OK? I know alcohol/ ethanol is hard on rubber.
1951 3100
JW51 #1235850 09/21/2017 5:43 PM
How about a strong solution or warm water and Dawn dishwashing liquid? If it takes crude oil off baby ducks without killing them, a greasy vacuum advance shouldn't be much of a problem. Ditto for Tide or one of the other heavy duty laundry detergents!
JW51 #1235852 09/21/2017 5:48 PM
Vacuum advance units aren't rocket science- - - - -why couldn't a more available item like one for a small block Chevy V8 be adapted to the stovebolt linkage? I'll bet I could spend an hour or two with a drill press, a hacksaw, and a few sheet metal screws and bring some of those dead ones back to life! I believe the stroke could even be made adjustable to fine tune the total degrees of advance in the process!
JW51 #1235854 09/21/2017 5:51 PM
J Online: Content
Will try that first. My experience with most of this fossilized crap is not very fun.
I try to think of it as a "protective" layer to avoid getting angry.
1951 3100
JW51 #1235891 09/21/2017 9:32 PM
Hey JW, I too have a 1962 Chevrolet 235ci motor, on my 1948 Truck (btw my Chassis is a '51). Here are a couple pictures. The distributor moves (counter-clockwise) about 1/5th of a turn, under acceleration.
I put a new Vacuum on it that I purchased from Bowtiebits.com (1947-55 Vacuum Advance Part Number: AD-475-MECV-945) and the tubing came from InlineTube.com (part CTV4702) The distributor is an original '48 setup, however, I put a Pertronix 1168LSN6 ignitor into it, which get's rid of the points setup. Still uses a rotor, but it's 2x as better spark I hear. The engine is configured with a 6V setup (6V coil, 6V starter, 6V Battery, a 139 tooth Flywheel and the 6Volt Pertronix Ignitor in the distributor.)
The carburetor is a Carter YF. The Vacuum line that attaches to the Carb, has a straight line with a brass BB that goes over the tube, but inside the nut (like a plumbing fitting). Everything works just fine with the setup. I tested the Vacuum pressure with a gauge that hooks up to the fitting on the outside of your Intake Manifold, just below the Carb. The gauge reads in mercury pressure or inches per Hg. Shop manual says the vacuum should be between 17-21 in/Hg I believe.
Hope this helps...
JW51 #1236026 09/22/2017 11:49 PM
I did a quick clean/check/regrease on my distributor this past week and discovered that the vacuum advance is inop; I guess I'll be looking for a new or working one as well.
Lee
1956 Chevy 3200, 235 w/3 speed
JW51 #1236029 09/23/2017 12:06 AM
Anyone who is willing to send me one of those non-working advance units would make it a lot easier for me to develop a possible modification to make use of a more readily available vacuum chamber. I don't necessarily need the clamp assembly that attaches to the distributor housing, just the advance chamber itself. PM me for a mailing address. Thanks!
JW51 #1236064 09/23/2017 12:35 PM
J Online: Content
I could get you one or two.
1951 3100
JW51 #1236079 09/23/2017 2:40 PM
Thanks! I believe it's possible to adapt a less expensive, more available vacuum chamber to the stovebolt advance bracket with a small piece of angle iron and a couple of sheet metal screws or pop rivets. GM used the same advance unit on virtually all their V8's for many years, so that would be a good candidate.
JW51 #1236097 09/23/2017 5:38 PM
J Online: Content
Good idea. I was pretty shocked they couldn't get one.
My local Napa store has been in business since 1909 (not always under napa flag). They can find almost anything.
1951 3100
JW51 #1236098 09/23/2017 5:40 PM
J Online: Content
Update:
Vac advance all cleaned up. Distributor pulled and cleaned up. Ready to set the dizzy back in...hopefully yet this afternoon.
1951 3100
