2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I am in the middle of a restoration on my 53, and was wondering what did they use in behind of the dash grill ? Thinking there was some kind of padding or something so you cant look all they way through to the firewall. Must be correct appearing. Any help is appreciated
Thanks, Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Steve,
I also have a 53. Some of these guys that have owned multiple trucks may have seen a solid piece of material back there. But, when I took my speaker grill off to paint, there was only a metal mesh piece back there. The mesh holes are small round holes. It had either lost most of its paint. Or, it just got some light overspray from the factory painting the outside of the speaker grill. I media blasted it several years ago and painted it black. It looks nice behind the speaker grill. You can see it, but you have to really get at the right angle to see through it. I chose to install the old, original radio back into the truck. There is no light that comes up from behind it. It you are not planning to install a radio, I would imagine you get a little light from behind the dash. Not much, but a little. I have not seen that piece of mesh in any of the reproduction catalogs. I suppose somebody on the swap meet page may be selling one. Or, look on line at the auction sites. Hope this helps. Good luck with your restoration.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Thanks Rugo, now I know what to look for. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I have a number of speaker grills of unknown vintage with the screen. I have a '52 which has what looks like tar paper and no screen. Did GM make this a part of their War Era metal conservation deals, or was this done by the former owner of this truck?
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Carl,
I have never seen the paper and screen on the same grills. I have removed these grills into 1949 but believe it was phased out as a running change sometime in 1950. | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Carl, my 98% original 52 half ton also has that same paper type material, no metal mesh so I also believe it was due to war era. Thanks. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Steve - I researched the cardboard radio grille screen for my '54 a few years ago. A cardboard baffle was inserted behind the dash grille at the factory. It was removed and discarded by the dealer when a radio was installed. Don't know about earlier trucks, but no wire screen or perforated plate was used in 1954. The cardboard screen is shown in a '54 dash in the Factory Assembly Manual. Here my old post about reproducing the cardboard grille screen in my '54". Photos were linked to Photobucket and no longer are visible. I can send to you if you need them. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=891514#Post891514The cardboard was described in the '51 installation manual. Similar description in the '54 Accessories Installation Manual. > 1951 Installation Radio 986515-986516: "Remove cardboard radio grille cover from inside of radio grille and discard." http://chevy.oldcarmanualproject.com/radios/51rs/51rs06.htm> 1951 Installation Radio 986443: "Remove the decorative plate, the two buttons from the center of the instrument panel and the black cardboard baffle from the rear side of the radio grille." http://chevy.oldcarmanualproject.com/radios/51rs/51rs41.htmBTW - Radios were not installed at the factory, so the plate is not a "radio-delete plate." A better term is a "radio block-out plate." Radios were installed by the dealer. - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Ha! Thanks all for taking your time to unravel this mystery for me. Once again Stovebolters rock!! 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | My '51 has a metal cover plate behind the faceplate and knob holes. Of course it was a non-radio truck, so they may have wanted something more permanent than cardboard.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
