7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl),
109
0
Mod | | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | On my 51, the rear stake pockets and tailgate hinge mounts are completely rusted away, flaky, and crumbly. Most of the rear parts of the bedsides are rusted away. I am not very experienced in that area, so patching it all myself is not really an option. Would it be cheaper to send it to a body shop or buy new bed panels with stake pockets and everything. I think they are 300 or 400 dollars a side. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | It may or may not be cheaper depending on what body shop you take it to and the extent of the rust damage, and there is always a chance if rust through again down the road after the repair. Personally, I wouldn't trust most body shops to do a repair like that. And if it's a good body shop that does restorations and not collision work, they will probably tell you you'd be better off with the new sides. Buy the new bedsides if you can afford it. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I agree with ghostrider. Wait till you can buy new sides or put an ad in the parts wanted section of this forum and see what response you get. Cecil.......... | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Bed side repair is fairly difficult because of the large flat panels. Most bodywork is done on curved panels, which makes bondo useful and tricks the eye- you can't see if a curve is slightly off. A bedside that is oilcanned or welded is really easy to spot. I would find another bed or get new sides if you can. I doubt you can pay someone to fix it right for less than you can get a bedside or a whole bed from someone.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | justin,
If its just the stake pocket that are real bad, they can be replaced separately. I've never done it but I understand that each spot weld needs to be drilled out and then the new pocked can be tack welded back in. | | |
