4 members (MickeyP, HandyAndy, Hotrod Lincoln, stlcardinalsguy), 48 guests, and 6 robots.
Topics128,022
Posts1,055,352
Members48,420
#1235024 09/17/2017 2:08 AM
Guys,
I am getting ready to pull the original 235 out of my 54 Chevy truck because it is smoking and using oil, and will eventually overhaul it at some point. For now I am looking at buying a later 235 that came out of a 59 Apache pickup to drop into my 54. What will I need to change on the 59 to get it to mount up in my truck? I know the front engine mounts on the 59 engine are different and I believe they are on the side, but can the front timing cover from the 54 be used on the 59, or is there something else I would need to do?
What about the rear mounts? I assume I can use the 54 bell housing on the 59 engine?
Thanks guys!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
kthomas #1235026 09/17/2017 2:18 AM
H Online: Content
The primary problem will be the position of the water pump. 55-up engines have the pump about 3 inches lower on the block and further forward which creates fan clearance problems. There is a conversion adapter available which allows you to mount a 216/early 235 water pump to the later engine that repositions the fan properly. It requires drilling and tapping two holes into the later model block, but that's not difficult to do.
The 54 bellhousing is a bolt-up swap, and the front timing plate can be drilled for the earlier mount if necessary.
Thank you Jerry!! I wondered about the fan position. Do you know who offers the conversion part?
kthomas #1235031 09/17/2017 2:40 AM
kthomas #1235051 09/17/2017 3:59 AM
You can adapt the timing plate to work on the '54 motor mount. The modifications can be made without removing the timing plate. I have done it with the engine on a hoist, just be careful and take adequate safety precautions.
The timing plate for the AD trucks has two square holes for carriage bolts to pass through. The bolts go from the top down and the squares hold the bolts in place when they are tightened up.
To modify the TF timing plate, which has no holes in the bottom, carefully mark where the holes would be for an AD truck. If you go to Deve's website...devetechnet.com...you can find very accurate measurements and a template.
Deve's instructions explain how to add the two square holes to accept carriage bolts. The problem is that one of the carriage bolts won't fit into the hole unless you do some tearing down to get at the hole. Instead, drill the holes and weld a nut in place on the crank/cam side of the timing plate. As I recall, the carriage bolts are 7/16 fine thread, so use that size nut. Then you can attach the motor mount by installing the bolt going up into the weld nuts instead of down using carriage bolts.
Very simple and easy. Does not require any tear down other than removing the harmonic balancer.
Matt
kthomas #1235054 09/17/2017 4:09 AM
H Online: Content
Originally Posted by kthomas
I believe I found the adapter.l
It's also on Ebay at a better price without the resto-ripoff markup. Search "235 Chevy water pump adapter".
Check out Pre 68 Dave's blog. He's the guy who makes the adapter and he has very good information about this (and many other topics about these engines) Chev 235 Guy
It's a small world, but I wouldn't want to paint it.
kthomas #1235079 09/17/2017 12:40 PM
Thanks again guys!
I checked out the Chev 235 Guy. Great article on how to do this. Thanks!!
kthomas #1235142 09/17/2017 9:16 PM
Here's why I am getting ready to pull the engine. It burned this in about 75 miles.
kthomas #1235163 09/17/2017 10:41 PM
Sorry, that link does not work.
tclederman #1235171 09/17/2017 10:58 PM
I edited the link. Try it now.
kthomas #1235180 09/17/2017 11:35 PM
No.
tclederman #1235185 09/17/2017 11:53 PM
I wish there was a better way to post a photo on this forum!
[IMG]http://i729.photobucket.com/al...after%2072%20miles_zpsdeitrxt6.jpg[/IMG]
kthomas #1235191 09/18/2017 12:09 AM
back yard wrench turner
Kevin[/quote]
The link won't work no matter how many times you try to post it.
You got caught by the Photobucket Rip-off. They want you to upgrade for 3rd party hosting.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
kthomas #1235197 09/18/2017 12:19 AM
Kevin, are you using your phone instead of a real computer?
You can post photos to this forum but you have to follow the site photo posting policy at the bottom left of this page. If your using a phone you can't see the policy.🛠
No, I am using my desk top computer. I was just going to show the oil stick being 2 quarts low.
Thanks for the information. I was trying to post the old way!
