5 members (massey1951, Otto Skorzeny, 1955 1 Series, JW51, 1 invisible), 112 guests, and 2 robots.
Topics128,037
Posts1,055,582
#12350 04/02/2003 12:50 AM
Ok, I acquired this torque tube with center section that has the Patrick's 3.55 conversion installed. I talked to Patrick and he said the easiest thing to do was to just replace my whole torque tube with this one. That way I wouldn't have to do any of the tedious adjustments.
My question is, what should I do to this torque tube before I install it? Is there anything I should replace? I assume the front joint? Anything else? I never had this apart before so don't know what to expect. My own torque tube works great without any leaks.
54 3100 with 235
62 flatbed dump C60 with 261
#12351 04/02/2003 1:11 AM
Send it to me and I'll try it out for a few year and see how well it works. grin
Paint & Body Shop moderator
#12352 04/02/2003 1:43 AM
Shucks, if I didn't have a truck to put it in I might consider it...
:rolleyes:
54 3100 with 235
#12353 04/02/2003 5:05 AM
Yeah ,, check the okie bushing at the top end , though if someone went to the trouble and expense of installing the Patricks gears , you would think they would have sorted the rest .
#12354 04/03/2003 3:43 PM
I guess I will just slap it in there then. :rolleyes:
54 3100 with 235
#12355 04/03/2003 4:26 PM
Check gear contact pattern, bearing condition, gear backlash, gear tooth condition, etc. If it all checks out, slap it in there.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#12356 04/03/2003 4:38 PM
Thanks.
So, I am thinking I will buy new gaskets for the front and rear of the axle housing, whatever gaskets fit at the front of the tube and a new U joint.
I will inspect the axle bearings and seals and just clean everything out before reinstall.
54 3100 with 235
#12357 04/03/2003 4:40 PM
Fel-Pro makes a torque tube gasket kit for the Ujoint bell. I bought mine from National Chevy Assoc in St Paul, MN. But I bet if you pester the kid at NAPA enough, he may be able to find it in a Fel-Pro catalog or Fel-Pro help line.
good luck
chip
