13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible), 123 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
JOD
Offline
Does anyone know where i could find a passenger side engine perch for a 292 C. I.
Its for my 65 Chevy C20 pickup.
JOD
65 Chevy C20 Fleetside
66 Chevy C10 shorted Fleetside
Most of us just move the right side mount pad forward, no need to go searching for another mount.
JOD
Offline
That helps thx
JOD
but when you want to do the job properly it is always best to use the proper parts if available and the motor lines up a lot better
https://imageshack.com/i/poFkANu7j
https://imageshack.com/i/pnn9jBMPj
ron
I had good luck in a junk yard. Quick and easy.
~ HB
1962 Chevrolet C10
1962 Suburban
I'm accustomed to starting with rectangular tubing and ending up with a frame that goes around in circles really fast. Adapting that mount is a 30 minute fabrication job.
so it is just more than moving the mount forward. not everyone is suited for fabricating things
I have also seen some cobbled up affairs there
ron
JOD
Offline
I found a pair of used Perch's. Tanks for the feedback it will be good to use the correct part.
JOD
The passenger side spring perch for a 292 is different than a v8 or smaller six cyl perch. moving it foreward does not make it fit.
