1 members (Otto Skorzeny),
54
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 5 New Guy | | New Guy Joined: Aug 2006 Posts: 5 | Greetings All Has anyone ever used those sanding disks that look like brillo pads that will either chuck into a drill or angle grinder? Not the little 2" 3M ones, these are 6" dia, and I've seen 2 different courses. If so, are they ok for frame work, underside sheetmetal ??? And how long do they last - better then sandpaper?
Pete Wrongpaw Adams
47 3100 (in progress - sort of)
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may have a bit of trouble getting into the corners of a frame with something that big.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I use them all the time. A tool store by me sells a brand called Face-Off in sizes from 4" up to 7". They're my favorite method for stripping paint and rust. Kind of expensive, but to me they're worth it. I use mostly the 5" size in my Makita GV5000 disc sander. A pack of 5 runs about $20.
They remove the paint and surface rust very fast and leave the surface of the metal ready for primer.
Bob | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Is that like a scotch bright wheel or pad? I was thinking about trying one.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
