7 members (Guitplayer, JW51, mo2cyl, Otto Skorzeny, 55shaker, Wally / Montana, 1 invisible), 73 guests, and 3 robots.
Topics128,050
Posts1,055,757
#123415 12/07/2006 7:26 PM
Greetings All
Has anyone ever used those sanding disks that look
like brillo pads that will either chuck into a drill or angle grinder? Not the little 2" 3M ones, these are 6" dia, and I've seen 2 different courses. If so, are they ok for frame work, underside sheetmetal ???
And how long do they last - better then sandpaper?
Pete Wrongpaw Adams
47 3100 (in progress - sort of)
#123416 12/07/2006 7:48 PM
You may have a bit of trouble getting into the corners of a frame with something that big.
Paint & Body Shop moderator
#123417 12/07/2006 9:51 PM
I use them all the time. A tool store by me sells a brand called Face-Off in sizes from 4" up to 7". They're my favorite method for stripping paint and rust. Kind of expensive, but to me they're worth it. I use mostly the 5" size in my Makita GV5000 disc sander. A pack of 5 runs about $20.
They remove the paint and surface rust very fast and leave the surface of the metal ready for primer.
Bob
#123418 12/10/2006 7:14 AM
Is that like a scotch bright wheel or pad? I was thinking about trying one.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
