| | | Forums66 Topics128,180 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well howdy do boys, been a year or so since I’ve posted anything due to a ton of various other things that have taken priority. Haven’t driven or worked on Old Blue since last fall because of my shattered right wrist, which is my wrist of prime use. So…..I’ve had a new pair of stock (you old timers here know I’m a 95% purist), repeat, stock rear leaf springs for her but haven’t had the strength or pain endurance to install them up till now. I’ve not had the privilege of changing the rear springs on a 3604 with the rear fenders and running board aprons still installed on the truck. According to the service manual, it’s a simple matter of installing J-1436-9 adaptor to the J-1436 bushing installer and popping the spring pin out after the lock bolt is removed. That’s all fine and dandy….if the fenders and apron are off!!! But with them on there is no way to use a slide hammer, just simply isn’t any room, period. So (again)…….either I spend the day pulling the rear fenders and aprons or come up with some sort of fixture that I can pry the pins out with crow bar or some similar sort of leverage. Or…..maybe, just maybe there’s still an old Chevy mechanic still kickin’ out there who has a secret way of pullin’ the pins without dismantling the customers truck. Denny Graham Pullin’ his pin (i.e., spring pin) in Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, Denny Hope you are healing well. It is good to "hear" from you. As usual, I might be misunderstanding the bushing you are referring to, but, here is a thread with a spring perch bushing remover. I revised the design for use with a beefier remover-bolt. If I am way of base, just let me know. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope, not the bushings Tim, got new springs for my 3/4 ton from Eaton Detroit Spring. Mike makes them off the original blueprints he says, they've already got the brass bushings pressed into them. The stage that I'm at is just getting ready to pull the "spring pins" to remove the old springs. They might just slip out but I doubt it. So I'm anticipating the worst case. I always approach it that way then when the worst case happens.... I'm not disappointed. If those pins just slipped out.....well that would be great, like a bonus, but I know better. I'll bet I'm in for a wrestling match. Here's what I'm talking about, it looks like there is more room between the fender and the rear shackle, but it's really only about 8 or 10 inches and again, not enough room to get a slide hammer in. And the front is only 4 or 5 inches away from the apron. http://www.pbase.com/dennygraham/image/166162303 http://www.pbase.com/dennygraham/image/166162304So....I'll try to see if I can work them out but its looking more like I'll be pulling the fenders and running board aprons off so I can use a slide hammer. Hows the life as a country gentleman going??? You and the little woman getting used to the life of leisure?? What cha working on now that you have all the time in the world? Moderator: It's my thread so I can talk off topic if I want to!!!!! Denny G Sandwich, IL
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Denny, I'm doing the same thing swapping out the springs. I was doing well using a 1/8" pipe and a end cap with a 1/2' fender washer banging on that washer with a hammer. Pipe is screwed into the grease fitting hole.
What I wasn't aware of is that the SPACERS go on the outside of the spring.
Now the shop manual says the spacers go on the inside of the spring yet I've measured and determined that the spring spacers need to, and are easier to install on the outside of the springs.
Sense your springs are still installed note where the spacers are, We're approaching a correction to the shop manual. So far two of us (3600) have found out that the spacers are located on the outside of the spring hangers.
I did remove the Fender after installing one spring incorrectly gracious it was a lot easier. Tie a two by four to your engine lift and tie your fender to that being careful removal is successful. I did that on the opposite side of my truck.
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Spacer washer is to the outside of the spring. The Forgings are the same for the ¾ thru 2-ton trucks but the springs are different width, that’s the reason for the spacer. 1 1/2 & 2-ton had 2 1/2" wide springs. This truck was all original when I bought it. Talked to the original owners about what had been done to it over the years and the springs are the ones it came with. http://www.pbase.com/dennygraham/image/166164955 No problem holding up the back end. http://www.pbase.com/dennygraham/image/166164954 But.....getting the U-bolt nuts off was a bear and that took me most of the afternoon. Had to unscrew them 1/6 of a turn at a time with a extra-long breaker bar. Even the ¾’ drive earthquake impact wouldn’t budge them with 1200 ft. lb. of torque. Thought that would have twisted the bolts off it the nuts got stuck. Now that the rear pin is out, just have to figure out how to get the front one. Almost positive I’m gonna have to pull the running board aprons. So…..that’s one dang near out. Looks like I’ll be spending the rest of the weekend on this project. dg
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Denny, On my 50 1 ton I took out the pins from the top of the shackle. On my frame there is a hole on the backside of the pin which allowed me to simply drift the pin out by "pushing" it rather than pulling. I was then able to do the lower pins on my workbench. I was expecting a bear of a fight too, but it went extremely smoothly. Mind you, I zip cut my old u bolts out, had new ones built and dropped my rear end to pull both spring sets for an overhaul. Check up inside of your frame for these holes on the top pin. maybe you'll get lucky like I did if you're going as deep as I did.
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | As Fox said, there is a hole in the frame that you can put a long drift through and tap the pins out from the backside. At least my '50 3600 had the holes there... and my spacers were also on the outside when I took the rear springs off. A bench grinder is my tool of choice for removing U-bolts. Yours sound like toast anyway, if you had that much trouble getting the nuts off.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the tip Fox, and you to Dave. I just rolled under to check that out while the coffee’s a brewin’. Yep…..got em holes thru the inside of the frame at the back and thru the gusset at the front. Man that would really be a big help if they line up as you say, and they do look like they line up. Never would have thought to look thru the inside since the service manual never mentioned it and working on my back half in the dark with the bed and fenders on doesn’t show much from the bottom side. If that pans out you’ve just saved me a days’ worth of work, and that orta be a in the Tips & Tricks.
And I did have Eaton send out new U-bolts with the springs in anticipation of a problem just like I’m having. Also needed shorter U-bolts because I’m removing the auxiliary stack that they had on top. Not a fan of re-using old bolts that have been under a frame and subject to the weather, rocks and tree stumps for 70 yeas. I’d burn them off but I’m not nuts about that with all the crap I’ve got in the barn that could catch fire. Most of my burning I keep on the other side of the barn where I do my welding. Besides, I’m not a very good hacker and I’m not working on a flat rate so although I’ll never use them on a vehicle, I might find a use for them somewhere else around the shop. And what the heck…..I needed the exercise anyway, right? Thanks for the tips guys, I knew I could count on someone having gone thru this punishment before to find a simpler way of approaching it.
Denny Graham Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A few weeks ago I replied to a question about the spacers by pointing to the instruction in the shop manual. The other day I checked my 1 Ton and the spacers are on the outside. I am quite sure that when rebuilt my truck I put it together the way it was when I got it. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It is common to plan on replacing U-bolts whenever they are removed, especially if one lives in the 'rust belt.'
Ed
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Since this seems to be one of those "How did they do it at the factory? areas of question, I'll make a point of taking some measurements.The location of the spacers can shift the center line of the spring about an inch, so it should be pretty obvious where they belong once the center line of the holes in spring perches are determined. That should settle it one way or the other whether the service manual is right or wrong. Remember now....those manuals were written from the engineers notes by a technical writer who probably never even saw the under side of one of these trucks. The tip than Fox and Dave posted was a good one and made the job of removing the pins a snap. I'll have to replace a couple of the pins because of wear and I need to order bushings for the shackles, Other than that, its just a pain in the ars crawling around under these old trucks at my advanced age and damned hard to even get up off the floor with the remnants of this broken wrist. If anyone is contemplating a spring replacement, I'd highly recommend Eaton Detroit Spring. My new springs are a near perfect match for the original springs. Only one small item the is different, the rebound clips on the old spring were 1/4 x 1 with 3/8 bolts and the replacements, 3/16 x 3/4 with 5/16 bolts. http://www.pbase.com/dennygraham/image/166170931 DG
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well…..you guys ready for this???? I dropped a plum bob from the spring perch center on the axle, and double checked it with a ’47 ¾-ton axle that I’ve got out back of the barn; 42.5” Center Line on both. Then laid out the 36” frame width plus the 4.25” for each side of the spring hanger to their outer edge, minus 2” to the center line of the two springs and come up with……42.5”. Which means there is a .5” gap at the “inside” of each of the spring hanger. So……your .5” shim washer belongs on the “inside”, just as the service manual says. This tells me that somewhere down the line the springs had to have been removed on my truck…unless they were improperly placed during production.
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Well Don't understand but. WIth my New Detroit Eaton springs installed with the spacer on the outside. Measuring Center Line to Centerline of the tits that go into the diff is 41 5/8. Measured the landings on the differential housing C/L to C/l and got 41 5/8. All measurements +-1/8"
Julian Carter
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | So I'm working on a '52 and Denny is working on a '47. Wonder when the change happened. That put the pacers on the outside. The tip. About the holes on the inside of the frame is well worthy of a ... special report.
Julian Carter
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Shouldn't make any difference Julian, '47 to at least '55 1st. 3604. Also Chevy and GMC should be the same. Mine Old Blue happens to be a '50 by the way which is 42.5", as is the '47 GMC that is in the picture below. The spring center line can only be two widths using the stock .5" spacer washers. its either 42.5" or 41.5". That is arrived at by taking the frame width, 36" plus the distance from the frame to the inside of the hanger opening, 1.75" (twice) then adding 1" to each side for the leaf center line, if you were to putting the springs in with the spacers on the outside and that wold give you 41.5", Shift the spacers to the inside and you have a spring center line of 42.5" which matches the spring pads on the HO52 axle housing.. Now....the most accurat way to measure the center line of the 2" pads welded to the housing, is to drop a plum line from the (inside or outside) edge of the pads making a mark on the floor and then adding or subtracting 1" to that for the center line. That will be 42.5". http://www.pbase.com/dennygraham/image/166182159Denny Graham Sandwich, IL
