2 members (TPR57C, 1 invisible), 315 guests, and 8 robots.
Topics128,159
Posts1,057,039
Members48,460
Page 2 of 2 1 2
I just found this three hours away. It solves a lot of my problems. I'm hoping to make the trip tomorrow.
https://s19.postimg.org/ba5nxy7lv/IMG_5320.png
So I brought it home today. I was getting it for parts but I'm tempted to use it. It was a 72 C30 motorhome. The guy is using the cab for another project. The cab was immaculate. He's using it for another project and they buried the camper. lol This thing only has 62,000 miles on it and it was under a cover when it was stored. Since it was a motorhome it's got a ridiculously long wheel base. 157" That might be cool for my flat bed concept.
https://s19.postimg.org/dds2svsar/IMG_5338.jpg
So since I've decided I'm using the 72 frame I was able to get some work done today. I got the hubs and wheels back on the 63 so I can push her out of the garage. I got the engine out and into the frame of the 72. It's just laying there for now I needed somewhere to put it. I'll try to get the cab off sometime this week and get busy dialing the new frame in.
https://s19.postimg.org/48zc9qosj/IMG_5468.jpg
https://s19.postimg.org/c4eh2ansz/IMG_5472.jpg
Very Cool!
When I had to swap the frame on my ' 63, I jacked up the frame and cab as a unit, then built an A-Frame through the open windows, unbolted the frame, and swapped out the tires/rims for a set of bare times. I then lowered the frame down on to the rims and rolled it out from under the cab.
That way I could swap out the running gear and roll the new frame under the cab, lift it and bolt it to the cab. Remove the A-Frame and put the original times/rims back on. That made the swap very easy.
From the pictures you posted, it looks like that process might work for you.
Photo content reported to Moderator for review and removal of non-stovebolt related photos.
Did I have some wrong pics up? Have they already been removed? I'm not sure what you are referring to.
Your photo hosting site has advertising content that is not G or PG rated.
I just sent pm to Martin to find out. Not sure what he is referring to yet unless maybe your photo folders allow us to see your personal stuff. Stand by. I will clarify.
~ HB
1962 Chevrolet C10
1962 Suburban
Ah, thanks guys. The recent stuff I've been sharing is hosted at postimages.org. I switched to it when I got duped by Photobucket. I had no idea there was any advertising at all. I haven't seen any. All I use it for is truck stuff so there shouldn't be other images there. I'll wait to hear what the issue is. Not intentional and I apologize.
When I open your photo links I see your intended photos but as I scroll down I see photos of scantily clad young ladies. Try switching hosting sites. Hambone can delete the photo post if he deems it inappropriate. I suggest everyone start using the new Stovebolt photo procedure outlined at the bottom left of this thread. No harm no foul.👋🏻
WOW! I had no idea! Maybe if Photobucket started that they wouldn't have to charge! Haha! I'll change how I use photos. Thanks guys!
Thanks stutter. I am enjoying your progress. You are making quick work of things and it is inspiring
~ HB
1962 Chevrolet C10
1962 Suburban
We'll, I changed my mind again. I think it's part of the process for me. I try not to have too ridged of expectations. I'm approaching this build as a "let's see what we end up with" so I can take advantage of finds and deals. I've decided to stay on my 63 frame. The more I looked at the 72 the more work it needed and the bigger that 157" wheel base got. lol I'll swap the front crossmember and suspension. The rear end is too narrow to use. I thought it was cool but it won't fit on my 63. They are both Eaton rear ends so I'm figuring I can use the dually hubs. I'll get another rear end eventually.
Since I'm keeping this frame I bobbed It. I had to do something to make me commit. Hahaha! Bare with me!
https://imgur.com/gallery/xK07k
I had a couple hours today before work so I started tearing into the 72 frame. I was able to get better measurements and it looks like I'll be able to use the narrow rear end. I just have to relocate some mounts. So I'm happy about that.
https://imgur.com/gallery/lax22
Managed to scrounge up enough lumber and some casters to build a cab dolly for this weekends work. I hope to get the cab off the 63 and and the suspension off the 72 so they can haul it off for scrap. Then it's time to start cleaning up the 63 frame for paint.
Here's my crude dolly. It's not pretty but it'll work. haha
https://imgur.com/gallery/gfZME
Built one very similar. They work great.
~ HB
1962 Chevrolet C10
1962 Suburban
I wasted some time this weekend trying to get the cab bolts off. I read how many people had trouble with them so I thought I'd save time and go right to cutting them off. My saw burned out. I borrowed a buddy's and the battery was shot. So it's still not done. Hahaha
So this morning I got the rear end off the 72. I unbolted everything from the front but the sway bar doesn't clear so I have to remove it. I ran out of time and had to get to work. I'll finish up in the morning so they can haul off the 72 frame for scrap. I need the room in my driveway.
https://s19.postimg.org/kd2yo5u6b/IMG_5669.jpg
I got lucky today dropping the crossmember. There was an emergency brake cable hanging up and I cut it off with an angle grinder. The frame slowly see-sawed up and out of my way. I'm lucky it didn't come up fast. I was able to control it the whole way up. Sure made rolling the front end out easier.
https://imgur.com/gallery/Rrrjw
Lucky you still have all your teeth! (You do, don't you? LOL!) grin
That was my first thought! LOL Pretty lucky. But honestly while I was removing bolts and jimmying things around there wasn't much force trying to pull it up. The cable wasn't pulled super tight either. I was leaning over it when I cut it and it lifted right into my hand so I was able to hold it and control it all the way up.
I got a better saw and got the cab bolts cut off today. Removed the steering column and e-brake stuff too. Now the cab is finally disconnected for removal.
https://imgur.com/gallery/IeJM0
No work on the truck this weekend but I spent some time in the garage. I got an area cleaned out so I could do some welding and realized I was out of gas. So no welding this weekend. LOL
So I spent some time working on an old grill I got a couple months ago. It's a 6 foot long commercial boiler that was supposedly changed over to propane. But I got it apart and realized all he did was change the connection. So it's time to drill some holes and do some more converting. It's a fun project.
https://imgur.com/gallery/DHDqD
I got a chance to brush up on my torch skills today. I haven't touched one in probably 25 years. I did well on the flat cuts but running down the sides was a bear. LOL I need the 72 frame out of my drveway so I can roll my 63 out of the garage. It's been holding me up. So I cut it up to fit in my pick up so I can haul it off to the recycler. My tow truck buddy has been way too busy to come by and grab it.
https://imgur.com/gallery/exSTD
I finally got her rolled out of the garage today to get the cab off. I was able to stand back a bit and check out how she looks with the back end cut off. I dig it. Can't wait to see a little flat bed on it.
I used the U bolt brackets from the rear end of the 72 to secure that contraption I built to attach to the cherry picker. Kind of cool using old stuff.
I did tons of prep and research and it payed off the cab came off with little effort. I had a buddy over for an extra set of eyes and hands but I could have easily did it myself.
https://imgur.com/gallery/74tDr
I pulled the crossmember and a few other things off the front end today. The rear cab mounts were barely hanging on. LOL I got one off and I'll get the other tomorrow along with the rear end. Then more wire wheel to get the frame ready for paint. I've got some fun ideas for paint.
https://imgur.com/gallery/6aSDg
Making quick work of things
~ HB
1962 Chevrolet C10
1962 Suburban
Thank you. I'm trying to keep things moving. I'm going to have to start buying parts soon. That's when things slow down. haha
That's how it usually goes. We either have the time for the work, or the money for the parts. Rare that we have both at the same time.
Keep us all posted on your progress. It's looking good so far.
Yeah, I'm heading into my slow season at work which means extra time and no money. haha But there's plenty of cleaning and painting work I can do till work picks up again.
Page 2 of 2 1 2
