0 members (), 107 guests, and 1 robot.
Topics128,260
Posts1,058,318
Members48,485
#1233369 09/04/2017 6:21 PM
On a 66 Chevy, where the parking brake cable goes into the backing plate on the rear axle, is there supposed to be some kind of seal in there? I have the cable component which is the cable housing itself on the outside of the baking plate, and a 3 fingered spring clip that holds it into the backing plate, which is also part of the cable housing. There is also a thin flat washer, but when it's it the backing plate, it seems too loose. I have looked in the manual, and some of the parts catalogs but see nothing. I do see in the LMC catalog that it shows some kind of a seal with a slot in it(?). Are any of you familiar with what should be in there?
Thank you for your help ahead of time.
I dont recall anything other than a push clip that seats the cable to the backing plate.
~ HB
1962 Chevrolet C10
1962 Suburban
Thank you, I'll have to take a closer look at it.
