3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#123330 12/02/2006 2:24 PM
I am wanting to replace the interior door panels on my '51 GMC. Read that the repo cardboard is problematic. As a woodworker I have 1/8"(-) maple plywood in my shop. Any thoughts how that would work with fabric applied?
#123331 12/02/2006 4:11 PM
If it will lay "flat" and you can "fit" it around all the cut outs, it would probably "work". If you have the time and tools to make the maple really fit the door, it might be interesting to just finish the maple. It would probably knock your eyes out!
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#123332 12/02/2006 6:58 PM
thomas,
Most likely I do have to tell you this; but, be sure to seal all sides of the plywood with something like marine spar varnish.
Tim
#123333 12/02/2006 7:09 PM
I think I would consider covering a flat piece of metal instead unless you want the look of the wood, uncovered. Metal wont be as thick, wont warp, doesn't need sealed other than a quick coat of paint. Probably easier to mount to the door.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#123334 12/03/2006 3:40 AM
don't know if you saw this thread but it had some good ideas for door panel treatments.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=20;t=000113
#123335 12/03/2006 5:02 AM
If you watch auto upholsterers on TV you see them using 1/8" plywood with foam glued on top, probably luan or something cheap. For the door panels I would use a marine or aviation grade plywood, which simply means they use a waterproof glue to prevent delamination.
Paint & Body Shop moderator
#123336 12/03/2006 5:03 AM
I am moving this to interiors, because it fits better there.
